need feedback; pushrod touching guide plate
Old Aug 6, 2006 | 11:20 PM
lgaff's Avatar
lgaff
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
Default need feedback; pushrod touching guide plate
1990 L98
Putting on SA 1.6RR on motor; all stock w/exception of rockers.....the pushrods are touching the guideplates on the #1/#2 exhaust valves(contact is on the side of the pushrod).....as i understand it these are not true guideplates.....but I need advice as to what I should do..they are barely touching but appears there is some contact
thanks
Lgaff
Old Aug 7, 2006 | 12:15 AM
lgaff's Avatar
lgaff
I think i may have answered my own question, as I understand it(from doing some Google research), push rods touching the guideplates(on the sides) is normal even with SA rockers...Correct?
Lgaff
Old Aug 7, 2006 | 01:46 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Can the assembly/guideplates be loosened and adjusted at all? They should not be rubbing.
Old Aug 8, 2006 | 10:47 PM
lgaff's Avatar
lgaff
Default Tried to adjust guide plate
I tried to adjust the guideplate, however the guidepaltes are grooved by the stud, so when the studs are torqued, the guideplate moves back as the stud falls in the grove....i assume I need to buy new....should i also replace pushrods?
Lgaff
To need feedback; pushrod touching guide plate
