ECM being flakey on 93 LT1
Old Aug 6, 2006 | 11:35 PM
jamie327's Avatar
jamie327
Default ECM being flakey on 93 LT1
The ECM on my 93 LT1 6-speed is doing some weird things. Sometimes the car will run fine, but other times it runs like its timing is off and throws an ASR and SES light, and I loose all digital gauges including speed. No codes are available when this happens, not using the paperclip method or a scanner. The scanner says it's unable to communicate with the car. If I pop the hood and tap the ECM unit everything springs back to life and the car runs great and there are no codes to be read.
I'm pretty sure this isn't related to a loose wire on the harness going to the ECM because I've jiggled them while the car was running and nothing happens. The only time I can produce/solve the problem is by tapping on the metal enclosure. I checked that the PROM was seated tightly. Am I looking at an ECM that's on its way out or needs to be replaced? Or is there a simple solution that I haven't been able to find yet?
Old Aug 7, 2006 | 12:14 AM
SunCr's Avatar
SunCr
Aim a hair dryer at it - usually when it's cold and running fine - if that duplicates the problem, it's probably a bad solder joint or cracked board and you'll need to replace it.
Old Aug 7, 2006 | 05:42 AM
MickeW's Avatar
MickeW
You need a new ECM..
http://forums.corvetteforum.com/show....php?t=1218103
Old Aug 7, 2006 | 07:16 AM
RRT vette's Avatar
RRT vette
Also try removing the connections and cleaning them...make sure they connect back good.
Old Aug 7, 2006 | 10:10 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I have the same issues and it turned out to be the ECM/CCM grounds located directly above the oil filter. Replaced the ECM and it was no help. Cleaning and adjusting the grounds did the job.
Old Aug 7, 2006 | 11:55 AM
pcolt94's Avatar
pcolt94
Some of the things you described sounds like CCM functions. I would be open minded and possibly looking in some different areas. All are good suggestions so far but it would take a lot of heat to get the ECM hot enough because it is a large mass of metal and you don’t really know what’s going on inside. It gets pretty hot during normal driving.
Although those year ECMs have a reputation, I would not change it so fast but look for an external problem (connection or such) before you go an buy one. Unless you just have a spare one to try.
Old Aug 7, 2006 | 04:18 PM
jamie327's Avatar
jamie327
Thanks for the responses guys. I'm leaning towards it actually being the ECM and not the connections on the back or a loose wire outside the unit. I can hold the ECM still, move the wires, and not replicate the problem but if I remove the cover for the PROM and tap the chip or board even the slightest bit the issues come back. So I guess it sounds like I need a new ECM.
Anyone know a good place to get one? I've checked the regular places out and everyone seems to be out of stock on them.
Old Aug 7, 2006 | 09:15 PM
tennis1's Avatar
tennis1
Default Ecm
Had the ECM changed a 2nd time at the dealer and now the car runs fine (only 20 miles so far), '92 was at the dealer almost a month waiting for the ac-delco part. Could get a aftermarket overnight but the dealer said they would not warranty anyhting that would "go" associated with "that" ECM only theirs.
Do you believe it- 1 "month" to get an american car part.
Old Aug 7, 2006 | 10:49 PM
jamie327's Avatar
jamie327
Tennis...where did you find an aftermarket ECM?
Old Aug 9, 2006 | 02:38 PM
jamie327's Avatar
jamie327
Ok...so I sourced a reman ECM local to me, installed it, and now the car won't even start. I'm getting ATS, SES, and SYS like I was before, but now it cranks and doesn't start. Getting a code 12 (using the paperclip method) but the code reader can't communicate with the car. Is there something that I need to do to reset the communications between the CCM and ECM or something? I'm 98% sure the old ECM was bad based on what I had to do to get the car to run properly, but now I'm questioning it.
Old Aug 9, 2006 | 03:24 PM
clf93lt1's Avatar
clf93lt1
did you put your chip in the new one ?
pcolt94's Avatar
pcolt94
Check the basics first. Fuel pressure and spark. A SYS is generated by the CCM. A code 12 says that there are no codes stored and the CCM is communicating and happy. The scanner interfaces with the CCM and if it can't, the CCM might not be working OK. If it cranks, VATS is OK but FEDS might not be.
I would not rely on fixing the car using codes, it may not be reliable and not yield real information. I think basic troubleshooting is going to be necessary in this case.
I cannot disagree with your physical initial findings, but I think you need to broaden the search and see what basic functions might be lacking.
Old Aug 9, 2006 | 03:29 PM
jamie327's Avatar
jamie327
Yes, chip came out of the old and into the new.
Old Aug 9, 2006 | 04:22 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Could be a bad prom.
Old Aug 10, 2006 | 03:51 PM
L71Maynard's Avatar
L71Maynard
Has anyone had their prom go bad and cause similar problems? I saw your post about the ground next to the oil filter solving your problems. I will be checking mine this weekend as I have had similar problems to yours since I got the car last September.
Dave
Old Aug 10, 2006 | 07:18 PM
jamie327's Avatar
jamie327
The ECM I originally received was bad, which caused the no-start issue. It was replaced with a confirmed working unit and I'm back on the road!
Old Aug 11, 2006 | 02:15 AM
MickeW's Avatar
MickeW
Nice
Old Nov 7, 2006 | 02:17 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
This might explain my problem.. Not sure if it's related, but, a couple of weeks ago my "low oil" light come on (even though the oil level was fine), I turned the car off and then back on, the low oil light never did return, but now i'm having the sys/security/asr problem. Not sure if the oil indicators sensors are at the same area as the ecm/ccm ground. I'll have to crawl underneath the car and look.
To ECM being flakey on 93 LT1
