door panel installation
Old Sep 6, 2001 | 01:14 PM
emoshn's Avatar
emoshn
Default door panel installation
I recently removed the door panel from my 92. In so doing, I ran into the little "S" shaped bracket which screws (on one end) to the metal door plate and the other end screws to the backside of the door handle. I was able, after thouroughly scraping my hand (by jamming it into the very small opening) to remove the bolt/screw holding the door handle. If you don't remove it, you can't get the door panel off.
Here's my question. HOW IN THE H--- DO YOU GET THE THING BACK TOGETHER? Is there some trick I'm not privvy to? It seems like a strange way to fasten the door handle to the door, but that's what they did.
Anybody else have this problem...and how did you overcome it?
Thanks, Dave
Old Sep 6, 2001 | 01:15 PM
emoshn's Avatar
emoshn
Default Re: door panel installation (emoshn)
By the way...I'm talking about the passenger door.
Old Sep 6, 2001 | 03:58 PM
emoshn's Avatar
emoshn
anybody?
Old Sep 6, 2001 | 04:01 PM
91-Z07Coupe's Avatar
91-Z07Coupe
pop off the window switch, the bolt location is directly behind it.
To door panel installation
