"front end wheel alignment specs please"
Old Aug 8, 2006 | 05:46 AM
sxyvet's Avatar
sxyvet
Default "front end wheel alignment specs please"
hi there guys,
hope all is well with you!
im getting a front end wheel alignment done tomorrow and need the specifiactions for "camber","toe in", "castor" settings for 1991 vette
the car has been lowered 2-3 " all round and is running drm coil overs on front!
can any one please help with the specs i need to take with me to the suspension place?
here is some old specs i found lying around from the prevoius owner for the front only!
toe in "0"
camber ".25 degrees negative"
castor "6 degrees positive"
the rear was
toe in "1/8" inch"
camber ".50 degrees negative"
cator "n.a"
thanks very much and look forward to some replys soon hopefully!
glen
sxyvet
Australia
Old Aug 8, 2006 | 06:06 AM
Steel Blue 91's Avatar
Steel Blue 91
Check out this article:
http://www.vettebrakes.com/NewsArticals/newsa.htm
My 91 likes the Advanced Street settings.
Old Aug 8, 2006 | 06:25 AM
sxyvet's Avatar
sxyvet
thank you steel blue 91 very much!
you were a great help mate!
cheers
glen
sxyvet
Australia
Old Aug 8, 2006 | 06:29 AM
86PACER's Avatar
86PACER
How's your tire wear with that setting?
Old Aug 8, 2006 | 10:02 AM
Steel Blue 91
I've seen no unsual wear patterns. I do rotate the tires when I do an oil change (every 3000 to 4000 miles).
Old Aug 8, 2006 | 10:41 AM
Sidney004's Avatar
Sidney004
For street use, I think those settings are right in the ballpark.
Old Aug 8, 2006 | 05:57 PM
sxyvet's Avatar
sxyvet
Default "thanks guys"
thank you guys for your wonderful help!!!
cheers
glen
sxyvet
Australia
Old Aug 8, 2006 | 06:05 PM
DieL's Avatar
DieL
Any time you change front settings you should do the rears too to make sure the car is 'aligned' . Changing the toe just slightly can throw off the thrust angle.
I used .25 front and rear camber with 0 toe and 3.5 degrees caster for more feel with the sport ratio rack that i love so much.
Also remember that the c4 suspension needs to settle after driving. if they jack up the car at all ( some alignment machines have mini lifts that lift the center of the car to install the alignment spiders on the wheels) it will throw off your alignment when driven and the suspension settles. you have coil over so you may not have an issue here but with leaf springs and even with custom length Bilsteins i had to pretty much align the car with +.25 camber all around because when it settled it would read -.25 (this is why stock c4s have positive alignment settings stock).
To "front end wheel alignment specs please"
