Ignition Module Wiring......Quick Question
Old Aug 9, 2006 | 09:22 AM
mn_vette's Avatar
mn_vette
Default Ignition Module Wiring......Quick Question
Hey guys, my car is dead and its the ignition system somewhere. So here's my question, there are 4 wires that go into the ignition module 1 black 2 white and 1 pink. The black is ground, but is the pink hot? I only have 0.5V on the pink. Could that be my problem? Or is that normal?
Old Aug 9, 2006 | 10:19 AM
rick lambert's Avatar
rick lambert
Was gonna try to help, but obviously the colors are different on your
1993 than on my 87. Helps to state the year.
Old Aug 9, 2006 | 10:29 AM
byedan's Avatar
byedan
i could be wrong but i want to say the white wires are hot 12v and the pink is tach and the black is ground
Old Aug 9, 2006 | 03:14 PM
bogus's Avatar
bogus
nope... pink is hot... white is tach.
if you are only getting a half a volt, something is seriously amiss.
Old Aug 9, 2006 | 03:34 PM
toptechx6's Avatar
toptechx6
Default Dvom?
Two things, first I'd check for codes, then verify your DVOM is in the right scale. The pink and one white wire should have 5 volts but the meter could make it look like .5 if on the wrong scale.
Old Aug 9, 2006 | 11:00 PM
mn_vette's Avatar
mn_vette
Its a really nice voltmeter, auto scaling, so that's out of the questions. It really is 0.457 V. Is there a fuse or something that could be blown?? I'd like to check that before I jumper 12V to it.
Old Aug 10, 2006 | 05:07 AM
toptechx6's Avatar
toptechx6
Sorry, I was incorrect about the 5 volt supply to the module, it should be 12 volts. The 5 volt supply is to the distributor.
My book shows supply voltage coming to the module from the coil , the coil does receive it's supply through a 10 amp fuse located in the fuse block at the right side of the dash, hot in start or run position of the ign. switch. hope that helps.
Old Aug 10, 2006 | 09:06 AM
mn_vette's Avatar
mn_vette
Thanks, that's exactly what I was looking for. I'll replace the fuse and see what happens, I may have to run a new wire if its something in between.
Old Aug 11, 2006 | 12:04 AM
mn_vette's Avatar
mn_vette
You are never going to believe what it turned out to be. I've got an MSD box with a little wire harness that plugs in between the vette wire harness and the coil. One of the connectors slipped off just enough to not make contact anymore and there went my 12V power. Just plug it back in and I'm now back in business.
Sometimes its the smallest things.
Old Aug 11, 2006 | 04:22 AM
toptechx6's Avatar
toptechx6
Happy to hear it was something easy and simple.
To Ignition Module Wiring......Quick Question
