total frustration
Old Aug 9, 2006 | 10:06 AM
walnut pony's Avatar
walnut pony
5th Gear
Default total frustration
Having a miss problem with my 1990 L98 for over a year and a half. Car was running fine until alternator failed while I was driving it . I did not notice the problem until the car completely drew down the battery and stalled. Had to connect jumper cables to recharge battery enough to restart the car in order to get home. Ended up having to do this four times to make it home. Replaced the alternator restarted the car and that is when the miss showed up. Repalced plugs with Bosh + 4s, plug wires with Accel 8mm and installed a new rotar in distributor. Restarted the car the miss was still there. Ended up taking it to a mechanic to have it looked at,found no codes,scoped it and found no ignition problems,checked for any vacuum leaks,checked injectors found nothing.Took it to another mechanic and had the same results,found no problem.Need help big time on this one! Anyone have any ideas.
Old Aug 9, 2006 | 10:27 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Wow, two mechanics? Then the obvious is probably out! I wouldn't think then that your present problem is related to the alternator problem. Did you change the cap? The Module? The fuel filter? You could also check you engine wiring to make sure you don't have an arching wire, or aloose conection on the injectors or other parts. A steady or random miss? Check the knock sensor wiring on the block by the starter, I've had that bite me.
Old Aug 9, 2006 | 11:08 AM
Fasterer's Avatar
Fasterer
Try pulling off one injector plug at a time while the car is idleing. Do any make no difference connected or not. Did either mechanic do a compression check. If you have compression, fuel, ignitionn, should have 8 cylinders
Old Aug 9, 2006 | 11:29 AM
rick lambert's Avatar
rick lambert
How bad is the miss, and in what RPM range? A bad coolant temp sensor can cause a miss....without throwing a code. You can also get a noid light a to make sure all injectors are recieving their signal. To many things on our vettes can and will cause a miss without throwing a code. Did they check the TPS voltages?
Old Aug 9, 2006 | 12:01 PM
Casethecorvetteman's Avatar
Casethecorvetteman
How are these items looking and when were they checked?
Fuel presure?
Fuel filter?
Intake air temperature sensor?
MAP sensor?
O2 sensor?
Alternator voltage?
Coolant temp sensor?
Knock sensor?
TPS working and within voltage spec?
Throttle body nice and clean? (including IAC path)
Is the issue constant or follow temperature?
Does the issue remain under all loads and RPMs?
Is the ECM wiring connected tightly as well as nice and clean?
Is the chip in firm and clean?
All sensor connectors nice and tight and clean?
See what you have left after that.
Old Aug 9, 2006 | 01:09 PM
redrose's Avatar
redrose
bad news is that when your old alternator died, it probably threw a ''spike'' at the ecm on its way out...not enough to smoke the ecm completely, but subtle trauma that will cause problems.
good news is that the -727 ecm used in your vette is the most common one at j-y supply(hordes of v-6's use the -727).... should be able to find one locally for $40, maybe less, ground yourself to the water faucet and change your vette prom into the j-y ecm....lots of ecm's here if you can't find one.
Old Aug 9, 2006 | 02:24 PM
mudslide's Avatar
mudslide
water faucet????
Old Aug 9, 2006 | 02:29 PM
Demonic85's Avatar
Demonic85
Originally Posted by mudslide
water faucet????
yeah buddy, stainless steel makes for a good ground.
Old Aug 9, 2006 | 03:43 PM
redrose's Avatar
redrose
if you are normal, you often carry a static elec charge on you that is sufficient to fry an integrated circuit on discharge...the same thing that sometimes gives you a jolt when you touch the car door handle...while the ecm prom pins are shielded somewhat by the plastic body, it is still possible to destroy the prom, or the ecm, if you are ''sparky''...touching the water faucet will USUALLY discharge the static charge, won't if all your pipe are plastic.
Old Aug 9, 2006 | 03:57 PM
85 Z-51's Avatar
85 Z-51
How do the plugs look? After a tune up I did last year I had a miss. After double and triple checking everthing else, , I pulled the plugs and put back in NGK's, and the miss was gone. Everyone of the +4's were gas soaked, almost like not hot enough. I'd take a look at those. That was the first and last time I used bosch plugs. AC Delco or NGK is the way to go.
Old Aug 10, 2006 | 02:32 PM
walnut pony
5th Gear
Did not occur to me that the plugs would be part of the problem. Other thing is the miss was present before I changed the plugs.Think I will take a look at them anyway. thanks
Old Aug 10, 2006 | 03:00 PM
walnut pony
5th Gear
Allready headed in that direction. Have in hand a #1227727 but having a hard time locating the EPROM.The ECM that I removed from the 1990 was a remanufactured #16197128 with a AOS Super Chip #9023A for 1990-1992 350 TPI manual transmission. Compatability issue there Im thinking. Anyway trying to find EPROM that is compatable with #1227727, which I have traced down to be AC Delco #16137184 = EPROM, ECM ( code 7185ARFP) (usage: Y 6-speed - Manual /Trans. (ML9), 5.7-8 (L98)
Old Aug 10, 2006 | 03:09 PM
walnut pony
5th Gear
I did change the dist.cap and the fuel filter but not the Module. Injectors are all new 1 year ago but ill check connections and take a look at knock sensor. Do you think it would be a good idea to change Ignition Module in dist.
Old Aug 10, 2006 | 04:40 PM
redrose's Avatar
redrose
possible that the chip was spiked too, PROBABLY won't hurt the ''new'' ecm if you tried it....new ac chips are now ''dealer only'' for some stupid reason, abt $70 there for ''shadetree's auto repair'', don't pay full list...i've seen em for less on-line but the ship+handle gets right back to $70.
hate to tell you, but the ign mod in the dist, your headlite module, wiper control, radio...all could be either fried or headed for early graves from an alternator spike or jump start spike--lets not panic tho.
Old Aug 10, 2006 | 11:01 PM
pcolt94's Avatar
pcolt94
Check the button for the rotor on the distributor cap to make sure it is in good shape and it is not broken or any insulation carbon tracked. Also, that the order of installation of the parts are correct. Has been a source of strange running and missing in the past. Best of luck.
To total frustration
