Burping Radiator--What did I do wrong???
Followed the steps below. Only difference is the engine was already warm (180 degrees). After turning the engine on I added a little more coolant and saw the level raising and lowering. My wife brought the engine up to around 1500 rpm's, I filled the rest of the way but before I could put the cap back on it started spewing hot coolant out the the radiator like a fountain.
Where did I mess up or do I have another problem?
Steps:
1. Add a mixture of one-half water and one-half antifreeze to the radiator. Fill it right up to the top.
2. Fill the overflow/coolant reservoir with the same 50/50 mixture.
3. Leave the radiator cap off, turn the engine on and let it run until the radiator "burps": You will see the coolant level drop and may see or hear a large air bubble come to the top as the system burps.
4. Keep an eye on the temperature gauge throughout this process.
5. Refill the radiator to the top and coolant reservoir as needed.
6. Put the radiator cap back on.
7. Note that if the engine runs hot after this procedure there may have been another pocket of air that "burped." Let the engine cool down and then add more coolant to both the radiator and the coolant reservoir.
Something so simple should not be such a pain....
1. Add a mixture of one-half water and one-half antifreeze to the radiator. Fill it right up to the top. Check.
2. Fill the overflow/coolant reservoir with the same 50/50 mixture. Only to the level marked, "Hot".
3. Leave the radiator cap off, turn the engine on and let it run until the radiator "burps": You will see the coolant level drop and may see or hear a large air bubble come to the top as the system burps. Keep feeling the upper radiator hose for signs the thermostat has opened (the hose gets hot) and keep checking the water in the radiator to watch for the water to start flowing or the level dropping. These aren't subtle changes. When the water level drops it drops a bunch, or when the water starts moving, it MOVES. At THIS time rev the engine to 2500 - 3000 rpms and add water. As soon as it has been filled, put the cap on. AFTER the cap is secure, you can reduce the engine speed.
4. Keep an eye on the temperature gauge throughout this process. Never a bad idea, but once the thermostat opens, things go pretty fast, and there is little time for gauge checking, or for overheating.
5. Refill the radiator to the top and coolant reservoir as needed. No. Don't remove the radiator cap at this point. Leave the reservoir alone also. The level shouldn't have moved much, if any, since you filled it to the "Hot" level.
6. Put the radiator cap back on. Skip, because you shouldn't have removed it.
7. Note that if the engine runs hot after this procedure there may have been another pocket of air that "burped." Let the engine cool down and then add more coolant to both the radiator and the coolant reservoir. After stop 6. it is fine to drive the car, but certainly not necessary. After the engine has thoroughly cooled, remove the radiator cap and add water to overflowing, if there is room. Also check the reservoir to be sure the water level is at "Cold" or slightly higher, is OK. One or two more cold checks after the engine has been warmed up, won't hurt.
RACE ON!!!
RACE ON!!!
RACE ON!!!
I think part of my problem was removing the cap again before it cooled down. Ran ok into work today. I will let it cool off and check it again tonight.
Thanks for the tips.
RACE ON!!!
There's been disagreement in regards to the practicality of drilling holes in the thermostat.
Drilling holes serves to make the car take longer to get to the same temps. It won't keep it from overheating if it already is. You just won't have to sweat it as much now when you are stopped at a light, because the holes provide a small constant flow of coolant circulation, making the car take longer to get to the same temperatures, reducing temperature spikes. It will still get up there in temps, just takes longer with holes.
Better than just drilling holes is to establish a properly maintined cooling system, and turn your fans on earlier than stock by either a custom chip or a low temp fan switch.
Checked the level this morning while it was still cold and added some coolant. So far it seems to be running around 189 driving on the highway and 205 to 225 in stop and go traffic. The weather has been hot and humid. Fan seems to kick on at 225 and off at around 210. I can live with that for now. May work on changing the fan on and off settings later.
Thanks for everyone's help.
86Pacer, I agree with everything you said, I just don't think you understood the point of the holes. This is to allow trapped air to escape from under the thermostat up into the radiator when filling, not to help with any cooling issues. For this purpose, it's a great mod.
86Pacer, I agree with everything you said, I just don't think you understood the point of the holes. This is to allow trapped air to escape from under the thermostat up into the radiator when filling, not to help with any cooling issues. For this purpose, it's a great mod.Last edited by 86PACER; Aug 10, 2006 at 07:53 PM.
