Gear Ratio Change/Speedometer Correction
Old Aug 9, 2006 | 11:04 AM
vette punk's Avatar
vette punk
Default Gear Ratio Change/Speedometer Correction
I am planning on a rear axle gear ratio change from 3.33 to 3.73 on my 89 C4 6 speed coupe and
need information and parts sources to correct the speedometer. How
is this done? Who sells the parts to correct the speedometer?
Thanks,
Jim B.
Old Aug 9, 2006 | 12:11 PM
toptechx6's Avatar
toptechx6
Default Two options
Thanks,
Jim B.
From what I've been told there are two ways you can go, see links below. I recently bought 3.73's and will likely change the trans gears. If the links won't work directly copy and paste into your browser search field.
http://www.ikerds.com/merchant2/merc...t_Code=400-083
http://www.dakotadigital.com/index.c...rod/prd126.htm
Old Aug 9, 2006 | 12:53 PM
tequilaboy's Avatar
tequilaboy
The combination of 15 and 45 teeth gears ought to do the trick for 3.73s and normal tires.
Old Aug 9, 2006 | 08:41 PM
CFI-EFI's Avatar
CFI-EFI
Changing speedo gears is MUCH more economical, and less work in your case. HERE is a tooth count calculator. Presently, your drive gear has 15 teeth. There should be no reason to change it. The calculator says to use a 43 tooth driven hear with 26" tall rear tires. You can buy these gears a lot cheaper at your Chevy dealer. The 43 tooth driven gear is part number 25513050. The 44 tooth gear is 25513051, and the 45 tooth gear is 25513052. Unlike some other ratio swaps, you will not have to change the drive gear or the VSS.
RACE ON!!!
Old Aug 10, 2006 | 06:16 AM
toptechx6's Avatar
toptechx6
RACE ON!!!
Thank you! You just saved me some money and aggravation, I was somewhat confused about the VSS, thanks for the clarification. Under what circumstances is changing the VSS required?
Old Aug 10, 2006 | 11:55 AM
CFI-EFI's Avatar
CFI-EFI
When the driven gear crosses the 39 tooth mark. It is similar to using a 2 series diff case with 2.59, 2.78, etc. gears, and a 3 series case with 3.07, 3.33, etc. gears. One VSS fits 35 to 39 tooth driven gears and the other fits 40 through 45 tooth driven gears. With vette punk changing from 3.33 gears to 3.73s, he had a 40 tooth driven gear. He won't be crossing that 39 tooth point when he swaps in the 43, 44, or 45 tooth driven gear.
RACE ON!!!
Old Aug 10, 2006 | 12:19 PM
toptechx6's Avatar
toptechx6
RACE ON!!!
Got in now, thanks for the explanation.
Old Aug 10, 2006 | 12:42 PM
sami85L98's Avatar
sami85L98
CFI-EFI helped me correct my speedometer correction, before i ask CFI i already bought n installed Dakota digi box that helped me correct speedometer but when i installed new tranny, at the same time i installed CFI's recomended combo and very happy with the result, now no need of dakota box. I bought these 15 and 43 from transmissionhead.com.
To Gear Ratio Change/Speedometer Correction
