Scanners re-visited (Again!)
Old Aug 10, 2006 | 04:56 PM
Blownfuel1's Avatar
Blownfuel1
Default Scanners re-visited (Again!)
So I want to get a scanner, but I need both OBDI and OBDII capability. I did a search on this on both this forum, and the Scan and Tune forum, but really didn't get the info I was looking for. I either want to get a lap top based setup, or the Autoxray EZ Scan 6000. I primarily want to use it for Diagnostics right now, but might eventually try to get into a little tuning. I can get a surplus laptop here at work for $250.00, which makes that option a little more appealing, but the only software my search brought up was the Auto Tap, and it's OBDII only. I will primarily be using this on OBDI vehicles (1987 Corvette, 1989 Lincoln, 1993 Camaro), but will also need to use it on my son's 1997 Ford Ranger (which is OBDII). I would like to stay around/ under $500.00, and I would like a data logging/ real time display of sensor readings (I hear the Autoxray EZ Scan 6000 may not be so good at this). I'm also a little confused as to the difference / importance of the " Supports multiple trouble code requests, generic codes (mode 3), pending codes (mode 7), enhanced codes (mode 13)" feature of the EZ Scan 6000, which seems to be the only difference between it and the EZ Scan 5000. Any suggestions / reccomendations? Thank's guy's, I know this comes up way to often, but I'm really confused!
Old Aug 10, 2006 | 05:18 PM
RRT vette's Avatar
RRT vette
From my recent experence and homework researching this, it will be better to get a laptop setup. It shows more on the screen where as the Autoxray you have to scroll through the data. I have not used a Autoxray and am only going by what other have told me and what I have used. You will need a laptop first, one with a USB port. Craig Moates is who I talked to on the phone and ordered his equipement for my 86. You will need a USB to ALDL converter (50.00) and OBDI cable (30.00) and for your case a OBDII cable as well. You can contact Craig and he will get you set up with what you need (real nice guy). I will post below some of the comments I received on threads I started about this. Others will chime in with more technical info.
http://forums.corvetteforum.com/show....php?t=1422874
http://forums.corvetteforum.com/show....php?t=1407324
http://forums.corvetteforum.com/show....php?t=1380382
Old Aug 10, 2006 | 05:54 PM
toptechx6's Avatar
toptechx6
I have the EZ Scan 6000 and it works great on my OBDII cars (all Chrysler) it has been a huge disappointment on my Vette. Your results may be better but I'd look at something different if buying again, good luck.
Old Aug 10, 2006 | 10:02 PM
Fasterer's Avatar
Fasterer
I brought the Autoaray 6000for my 85 with all the bells and whistles. I can even do the software upgrades over the internet and am having problems. Just got an answer from them that there is a software issue that is unresolved for me at this time. I spent the bucks for nothing.
Old Aug 11, 2006 | 12:44 AM
comp's Avatar
comp
Old Aug 11, 2006 | 12:53 AM
rickneworleansla's Avatar
rickneworleansla
I use my laptop with TTS Datamaster and TunerCat software with a custom tune from PCMFORLESS for my 95. It is the best setup you can have IMO. I don't know if it is best for your applications though or if it will work on all your cars. Visit the websites for info on the software.
Good Luck
Old Aug 11, 2006 | 05:44 AM
toptechx6's Avatar
toptechx6
Sounds like we have the same scanner, I recently wrote AutoXray Customer Service regarding my problems and await their reply. I asked to return the scanner for a refund since it does not perform as advertised, I'll post an update if they reply. Good luck with your issues, please let me know if they are able to help.
Old Aug 11, 2006 | 07:27 AM
Da Mail Man's Avatar
Da Mail Man
......what is this so-called problem with the auto x-ray 6000?........i have one and it works flawlessly.......
Old Aug 11, 2006 | 08:15 AM
Sam Lam's Avatar
Sam Lam
Blownfuel1: I have been on the same path as you in that I am looking for software to scan my 89 (I already have the laptop). A local Corvette friend (who does tuning) has scanned my car with a software package called Turbo Link and here is the web site : http://www.turbo-link.com/tlink/details/cattlp40.html
This software and cable package costs $295 and worked great on my car. I plan to buy this package.
Old Aug 11, 2006 | 10:01 AM
Fasterer's Avatar
Fasterer
Won't scan my 85 properly. One thing is i keep getting is a code 36 shift problem. Code 36 is not a shift code on an 85. By grounding diag plug i had a 42,43 in memory that the ez 6000 never even picked up. I no longer trust it for my vet. Thats what prompted the purchase of the cable to up load the latest software that did not fix my issues.
Old Aug 11, 2006 | 11:27 AM
Blownfuel1's Avatar
Blownfuel1
Thanks Guys,
Think I'm going to stay away from the AutoXray, probably go with the laptop set up, but I have noticed some pretty good deals on used Snap On MT 2500 scanners on Ebay lately, and I've used them without problems on Vettes, but I haven't used one a whole lot . Anybody have any comments on them?
Old Aug 12, 2006 | 12:25 PM
dlmeyers's Avatar
dlmeyers
Anybody have any comments on them?[/QUOTE]
I use the SnapOn MT 2500.(And occasionally a Tec1A) and like the MT2500 for general repairs.
Indeed, they are getting cheaper. They have discontinued the model but there are thousands around and SnapOn is providing some support, but not much. There are several units, older style no back lighting, backlighting, color, whatever.
For your application, you will need a minimum of two cartridges. The domesitc from 83-95, and the most recent OBII you can find. I also have the 1996-2000 cartridge(along with the 83-95)and it covers eveything I own, for now.
The OBDI connectors can get expensive. Buy a unit with lots of connectors. Make sure you get one with an OBD2 connector.
Snap On has an updated cartridge that flashes memory but are around $600-$1000, if you can find one. For your applications, should be able to find a good unit for under $500. There is plenty of documentation on these units and they are still in use by lots of professionals. Consider finding a SnapOn truck and asking about any used units, that is how I got mine. Go informed and try to get an Ebay price.
I love mine. It has paid for itself.
dlmeyers 90 coupe zf6 3 speed shocks
Old Aug 12, 2006 | 02:31 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
My old snap on scanner had the same problem scanning the 85's in real time mode...I think it may be the cause of the ecm not the scanners fault.I could be wrong though.Any car after 86 I could use it,go drive with it plugged up and watch all the data live and etc.Any car before 86 it would not show me much except trouble codes and etc.
Dont know...I would find out if that has anything to do with it,being an older ecm and model.
Old Aug 16, 2006 | 12:56 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Ease Diagnostics sells a laptop based scan tool for OBD1 and OBD2. It is the only laptop based scan tool the CA Bureau of Automotive Repair uses to teach their inspectors on. I know because I sold them the tools.
The Ease GM OBD1 scan tool will scan ALL GM OBD1 vehicles using the GM specific powertrain parameters. The Ease GM OBD2 scan tool will scan ALL GM OBD2 vehicles. You can scan and record hours of data. You can show the current and playback data streams in meter, number read-out, or chart mode. The OBD2 tool will let you actuate/disable all kinds of powertrain components while the car is running using bi-directional control. Depending on the model and year, it includes the transmission, ABS/ASR, and CCM controller parameter sets, as well as the vehicle's powertrain specific parameter sets. You can even get a wireless interface unit, so that while the interface is in the car, the laptop can be 50-100 feet away.
I would be glad to send an HTML write-up showing screen captures of the OBD1 tool in actual use on my 88 Vette. I used it to solve a faulty ECM problem. I can get a 10% discount for anyone interested. PM or email me.
To Scanners re-visited (Again!)
