HELP.TTS Datamaster not reading a 1990 Vette?
St. Jude Donor '03 & '05
Okay , it wouldnt work because its different software for different years. Can I use my code for the software I bought? Or do I have to buy new codes everytime I read another car ?
I currently have TTS Datamaster for the 93 LT1.
Yup, some cars will use the same definition but not many. You need the right "layout" for the data your getting for the '90.
I think TunerPro comes w/ the '90 as the free sample. I've used it on my '90 just a few weeks ago. I will admit I had a heck of a time getting it to work but once I did.... very cool.
Originally Posted by steve40th
Okay , it wouldnt work because its different software for different years. Can I use my code for the software I bought? Or do I have to buy new codes everytime I read another car ? I currently have TTS Datamaster for the 93 LT1.
Originally Posted by mseven
They claim they will give you up to 3 times free on the same program based on comp. crashing. When using different software for the 90 they want an additional 40. for each program, and claim code will only work on each application. But you can always down load the 90 datamaster and try it.
hi there guys,
sorry to but in on your thread but i have also brought the tts data master program for my 1991 model and ordered the one for 1991 model and brought a aldl cable but the program for some reason says it is not communicating with the ecm and there fore can not scan/run program!
any ideas what i could do at all please?
can i use the aldl cable to run with tts data master program?
thanks guys
glen
sxyvet
Australia
thanks guys
glen
sxyvet
Australia
Originally Posted by sxyvet
hi there guys,
thanks guys
glen
sxyvet
Australia
thanks guys
glen
sxyvet
Australia
http://www.ttspowersystems.com/adapt_cable.htm
Or Cable one on this order page ,
http://www.akmcables.com/ic.htm
I have to go to My Computer, Hardware and tell the port "disable" then enable onceor twice then it will communicate on my 93.
It needs to be the cable they specify on there site.
hi there steve,
thanks for the info mate!
i went tts datamaster site and they dont make obd1 cales any more!
and akmcables only have pay pal set up which i cant get here in australia!so not sure what to do now!
thanks for your time and help steve!
cheers
glen
Australia
hi there steve,
cheers
glen
Australia
cheers
glen
Australia
Well you can see if anyone in Aus can make you one, or have someone send you a cable after you send them some money. I would post a message on the General area to see if anyone in AUS or close by has a cable, or is able to help you get one useing whatever financial means. The shipping there wouldnt be too bad, I would imagine. Steve
thanks for your info/help mate!
all the best
glen
Australia
