If I remember from my rebuild...the bore and stroke is 4.00 and 3.48.
I was looking at new heads....anyone correct me if i'm wrong, but I think 64cc would give you a 9.1-9.2 or there abouts and the 74cc would be right around 8.2-8.3 range. It also depends on the gasket thickness that you would go with.
How much of a difference in compression ratio would I see if I went from a 58cc head to a 64cc or a 74cc head?
Is there a linear relationship between the cc's and the actual compression ratio?
Say I 'm at a 9.75:1 with a 58cc 113 head , but moved to a afr 195 with a cc of 64cc or 74cc.
If you can figure it out ,could you figure it out with both the 64cc and 74cc?
I went from 76cc to 58cc with a .051 compressed head gasket and .025 deck height and I figured I went from 9 to 10.6 so you'd be going the other way if you can try to keep the deck and head gasket total to under .05 to optimize quench. I couldnt on my setup or I'd be over 11.2 CR.
YOU can figure it out. And you can do as, or more, accurately than with one of those "calculators" that require input that you can only guess at. Figure backward from your known cubic inches and compression ratio to get the "above the piston volume". That number will be greater than the ccs of your head, but the number includes the head ccs. Add 6 ccs (64 - 58 = 6) to the calculated, above the piston volume number and re-figure the CR for the 64 cc heads. Once you have your "above the piston volume", you can easily figure the compression ratio for any single, or known combination of parts, change, such as head gasket thickness, piston dish or dome, deck height change, etc.
Ugh.... I do not know the Head Gasket Bore Diameter , Compressed Head Gasket Thickness , Piston Deck Clearance and such as I did not build the engine.
So, 1990dtgL98 thank you for your input, it was at least an attempt.
I thought that with the knowledge on the forum, a general (fairly close) answer could be attained. Oh well...
So, say the 74 cc heads dropped me a full CR point, without getting into the engine, how much could I get the CR to increase via gaskets and/or other means?
I'd like to figure what CR I would get with a .027 head gasket vs the stock .054?
Call me whatever, but I am not sure of the math CFI-EFI is getting at...
Well
you'll have that info when you build the topend backup. If it is the original engine. Standard deck height is roughly .025 and you probably have a .038 gasket. But that is just speculation. You're CR will always be lower than it is now because you are increase the volume of your heads. Even With a thinner gasket and a lower deck height I dont think you could offset the larger volume heads.UNLESS you change your pistons. I dont know if you want to get that involved in the rebuild.
Use one of the calcs as recommended to give you theoretical CR's with numbers above and just change the head volume . Watch how much the CR changes. There are several thin head gasket available out there just remember that when you start to reduce the deck and gasket height that piston to head clearance gets closer at TDC. So you also have to watch your piston to valve clearance if you are running larger than stock rockers.
Hey Steel Breeze, I used one of those calculators and started inputting what I actually did know, then adjusted the other numbers til I hit a 9.5:1 CR.
I then changed the head gasket from 0.54 to 0.27 and CR seemed to jump half a point.
By the way, just adjusting the cc of the heads from the stock 58 to 64, I lost half a point, and continuing to 74 cc from 58 I lost a total of 1.25, down to like an 8.25.
Again, not sure if I'm right or wrong, but 1990dtgL98 guessed around an 8.2 - 8.3 so it might be right.
In the articles I've read, one of which did actual back to back dyno testing to show the difference in power attributal to CR, one point in CR translates to between 3 and 4 percent difference in power.
This percentage isn't totally linear though. As I recall, going from 8:1 to 9:1 CR resulted in a higher PERCENTAGE increase than going from 10:1 to 11:1.
As a rule of thumb, 8 to 10 ccs translates in a 1 point CR change, So 4 to 5 ccs would translate into 1/2 pt. If memory serves, years ago when I did the calculations, the change wasn't linear either. Up to 400 CID or so, the cc change pretty much holds but beyond that CID the effect is different.
Sorry I can't recall the specifics but you can do it yourself and just run the numbers.
That is kinda what I have heard. I know that increasing combustion chamber size will drop compression. Thanks Man...
Thanks, Perhaps I will call the machine shop here in town, and see what he has to say, just for the fun of it...
You don't need to. See post #6, directly above the post I've quoted here.
It is pretty basic, really, as I mentioned in my post #6. You know that the compression ratio is the relationship between the swept volume to that of the total cylinder volume, right? You know that the engine has 350 CID of swept volume, right? Then you know each cylinder has 350÷8 cubic inches of volume, right? If you know the engine has a 10.0:1 compression ratio, then you know that the volume above the piston is 1/10th of the cylinder volume. Take the bore (350 CID = 4.00") and stroke (350 CID = 3.48") convert them from inches to metrics and figure the cylinder volume in ccs or liters. Then apply your compression ratio to determine the volume of the space above the piston of your engine. That volume you will be figuring will be the combination of all the of the volumes that make up the CR. It includes the deck height volume, the head gasket volume, the piston dome/dish with any possible valve reliefs,volume, and of course the cylinder head volume. Once that "above the piston volume" is known you can apply any variables you wish, collectively, or one at a time, and re-figure the resultant compression ratios. Easy, huh?
RACE ON!!!
PS. Watch out for those 1/4" and 1/2" thick gaskets.
