Headlight motor question
Old Aug 12, 2006 | 05:00 PM
357L98's Avatar
357L98
Default Headlight motor question
85 with later model headlight conversion. I just noticed one of my headlight motors continue to run for a few seconds after the assembly has fully raised or lowered. It looks like the motor is trying to cycle back and forth for some reason, but the headlight remains in the proper position. It has never failed to raise or lower. Am I destined to have a one eyed car? What should I do about it? Thanks!
Old Aug 12, 2006 | 05:09 PM
c4 4 me's Avatar
c4 4 me
My '86 would go down but not up. Took it apart cleaned and lubed it with no lue. Sent it to corvette cental for rebuild no more problems. Expect to replace it in the future they usually don't fix themselves. Part of the joy of pop up head lights.
Old Aug 12, 2006 | 07:32 PM
Javwho1's Avatar
Javwho1
The Delrin bushings are going on the light. You can order them at Eckler's Corvette America etc. They cost about $5.00 Enclosed you will find a link that will walk you through fixing them. Might as well do both lights at once, because once you fix one the other one will go.
http://mywebpages.comcast.net/zrjuan/headlight.html
good luck
Old Aug 13, 2006 | 12:15 PM
357L98's Avatar
357L98
That's a great link you sent, I'm going to save it for future use. I guess I better order some bushings. Thanks!
Old Aug 13, 2006 | 10:47 PM
Javwho1's Avatar
Javwho1
Glad I was able to help. I have a 3 inch binder that I keep many of these things in that way if I need something its there.
Old Aug 14, 2006 | 11:11 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
good luck
The 1985 models DO NOT have Delrin bushings. That was the later design in the 1988-96 models.
Old Aug 14, 2006 | 05:47 PM
357L98's Avatar
357L98
My car has the 88 and later headlight conversion, so I guess it would have the delrin bushings. I'm not really sure why that would make the motor run back and forth, but I will give it a try.
Old Sep 5, 2006 | 10:06 PM
357L98's Avatar
357L98
Replaced bushings with new ones from Eckler's, and the headlights work great!! The kit is now 5.99 for each motor now, so they went up a little bit. Thanks for the good advice!
To Headlight motor question
