MityVac for bleeding ABS
Old Aug 12, 2006 | 09:28 PM
ceberus's Avatar
ceberus
Default MityVac for bleeding ABS
I'm about to do the brakes on my 92 C4 and a friend mentioned the mityvac for flushing the brake fluid. l am wondering if this tool is safe to use with an ABS system and does anyone have any experience with it or recommendations?
Tx.
Old Aug 12, 2006 | 10:07 PM
Great White North's Avatar
Great White North
I use one every time I flush my 88!!
Old Aug 12, 2006 | 10:16 PM
Sam Lam's Avatar
Sam Lam
I just bought a Mityvac from Sears at a cost of $70. This is the aluminum version and I used it for the first time today on my "other" 2003 car. I flushed the brake system and added new fluid. This was an easy task with the Mityvac tool. The 89 Vette is next! I highly recommend this tool!
Old Aug 12, 2006 | 11:50 PM
Fast Eddiz's Avatar
Fast Eddiz
The nice thing about the Mityvac is you can bleed the brakes by yourself. One problem I've encountered using the Mityvac is a small amount of air bubbles slipping by the threads of the bleeder screw. I've tried using teflon tape and pipe compound on the threads but still get the tiny bubbles. Once I see clean fluid entering the Mityvac I'm guessing the lines are clear of bubbles. It works pretty slick!
Old Aug 13, 2006 | 12:24 AM
rightofway's Avatar
rightofway
i couldn't get my mityvac to completely seal to the nipple
it seemed to let air by and made bleeding take a while
Old Aug 13, 2006 | 12:47 AM
ALLT4's Avatar
ALLT4
I've always wondered if these things worked?
Old Aug 13, 2006 | 01:52 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Absolutely.
I only use the mityvac on my clutch system. No need with speedbleeders on the brakes.
I'd put a speedbleeder on the clutch but it's too close to the tunnel.
Old Aug 13, 2006 | 02:07 PM
runner140*'s Avatar
runner140*
They are SpeedBleeders and they work great. I've had them for a couple of years and use them for complete brake flushes. They're fast, easy and a one man job.
Old Aug 13, 2006 | 11:22 PM
Gary04Z06's Avatar
Gary04Z06
I use the Motive Power Bleeder.
http://store.summitracing.com/partde...5&autoview=sku
Old Aug 14, 2006 | 01:13 AM
Mo_Bandy's Avatar
Mo_Bandy
I just used mine this weekend on my brakes... worked fine... I used a little larger hose to slip completely over the bleeder valve and it worked just fine...
I'll be posting the brake upgrades on my web site soon...
Mo
To MityVac for bleeding ABS
