upgrades done=report
Old Aug 14, 2006 | 12:19 PM
96 lt-4's Avatar
96 lt-4
Default upgrades done=report
i just finished a few upgrades and thought i would post the results.
just installed the r-d camber brace and hadmy front wheels rebalanced with the hunter roadforce balancer i have seen suggested so many times.WOW.the steering is alot tighter and turn in is quicker.the death shake i have been experiencing at 60-65 mph is still there but barely noticeable.a HUGE improvement.maybe now i can drive with the top out!
i also upgraded to the earl's hyperfirm stainless brake hoses.the pedal is firmer and the brakes seem to respond a little better.i am comparing them to 97k originals though.
i installed the enlarged MAF housing that mid america sells.i had already de screened the maf.installed the stock sensor in the MAM housing.low rpm and part throttle response is much quicker!i know seat of the pants testing can lie but better throttle response is easy to tell.i expected the least amount of gain(if any) from this part.a pleasant surprise!
the MAF was purchased from member evolution and the camber brace from member knsrsr5r(probably goofed that one,sorry erik).both purchases were clean and trouble free.good guys!
Old Aug 14, 2006 | 01:27 PM
bogus's Avatar
bogus
I like the camber brace, it does improve things, a lot.
as for the brake lines, I suspect, to be honest, that fresh fluid had as much to do with the pedal improvement as did the lines... but they won't hurt... I have some Goodridge SS lines on mine, they are quite nice.
Old Aug 14, 2006 | 02:45 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Sounds like it's all good! Except for that little shake you still have...any ideas on that one? Well, if it's not balancing, then it's still something in the front suspension, right?
Old Aug 14, 2006 | 04:14 PM
96 lt-4's Avatar
96 lt-4
i don't know what gives on this one.if anyone has ideas on where to look please let me know.i do still have the original adj. shocks on there.for what the dealer wants for new ones they will be on there for a while.
it doesent do it all the time,only around 60-65 mph.it is smooth everywhere else.
could it be in the steering rack?
Old Aug 14, 2006 | 11:13 PM
franks96ce's Avatar
franks96ce
i have the same problem with mine if some one has any suggestions let us know.
Old Aug 17, 2006 | 01:38 AM
A95Y's Avatar
A95Y
Did you have your wheels/tires "road force" balanced? How many pounds of road force variation did they exhibit? To take the most advantage of the road force balancing machine, all your tires and wheels need to be the same size. You either have a balancing problem or a tire/wheel runout problem. The most effective way to balance the wheels is to put the weights on the inside and outside. Were they dynamically balanced? If all the weights are on the inside, are the outer weights as close to the outside as possible? If the weights are hidden behind the spokes, this is not the most effective balance. Do you have a set of known good tire/wheel combination you can put on your car that do not vibrate?
Old Aug 17, 2006 | 03:02 AM
Gar's Avatar
Gar
Original shocks? 97K is a ton of miles for a set of snubbers.
Old Aug 17, 2006 | 07:45 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
This may be true, but as said, the cost of exact replacements is a lot. That doesn't mean, however, that 96 can't go to non-adjustable shocks which are less costly. Even premium shocks might be less costly than adjustable replacements.
I read more into what cheetah's saying re the balancing and how it's done as well as that it's done at all. The only problem there is that it sounds like 96 does not have an extra set of wheels/tires that don't shake.
And btw, I've not seen before that all wheels and tires have to be the same size to make max use of the road force balancing---cheetah, can you explain why that is? Thanks.
Old Aug 17, 2006 | 10:52 AM
96 lt-4's Avatar
96 lt-4
i was not present when the front tires were balanced.they were done on a road force balancer.i do not know how much force was applied.we did check them on a spin balancer after.one was perfect and the other one was 5 grams off.the fronts are 255/45/17.there are no weights on the face of the wheel.
i have a set of sawblades and michelin pilot sports(un tested)i could put on there.it isn't bad enough to swap out(i'm lazy and it did improve from before).
i havent decided on defeating the adjustable suspension.i have a frien at the dealer who has quoted me a good price($200 off)but $800 is still alot of coin for shocks.
Old Aug 18, 2006 | 12:33 AM
A95Y's Avatar
A95Y
After you have balanced all 4 wheels and mark each tire/wheel combination, you ask the machine for the best placement....you can either have least vibration or least pull. If you have different sized tires, you have to put them in their respective front or rear positions. If they are all the same size, there are 4 choices of location for the machine to determine which combo is going to maximize your "least vibration" or "least pull" choice. It will still work with force matching the tire to wheel combo per unit, but it does not maximize the machine's capabilities.
The gentleman with the vibration stated it took a few grams. What I mean to say is that the road force is measured in pounds. There is an impercievable spot in your tire that is the heavy spot. The spot is measured in pounds. This information should be on your printout.
Old Aug 18, 2006 | 06:31 PM
OldCorvetteFan's Avatar
OldCorvetteFan
Cheetah -
So what do you do with different sized wheels front to rear and wheels that are designed to be mounted in a specific orientation?
I've got sawblades all around - so there is a particular orientation left to right. Since I also have 8.5" wheels on the front, and 9.5" wheels on the rear, then I also have specific wheel/tire locations.
If the machine says swap left to right, then doesn't that mean that you have to dismount each wheel and tire, remount, and then perform the balance all over again? How would you ever get done - it just seems to me like every iteration could make everything worse (or better - but it sure looks like a random condition).
I guess I can skip road force balancing on my next balancing operation - if you have to move things around, you'd best have symmetric wheels and non directional tires!
I'm not disputing what you've posted, but it sounds like more trouble than it's worth. What am I missing, guys?
Steven
Old Aug 18, 2006 | 07:03 PM
95wht6spd's Avatar
95wht6spd
Bad ball joint?
Old Aug 18, 2006 | 11:47 PM
A95Y's Avatar
A95Y
Steven
I don't think you're missing anything. The wheels and tires on your car have to be placed in a certain position on the vehicle. The only benefits you may see, is of the wheels being balanced in conjunction with the nominal runout of the wheel and tire and the heavy spot of the tire. It may be of benefit to see if the unit is "out of spec" and needs to be "force matched"(indexing the wheel and tire). Sometimes the tire and wheel cannot be brought into spec and the tire or wheel needs to be replaced, most often the tire. I road force mine even though they are different sizes just to see if the tires are cause for a potential problem.
Old Aug 19, 2006 | 07:20 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Cheetah -
Steven
"...It will still work with force matching the tire to wheel combo per unit, but it does not maximize the machine's capabilities. ..." Cheetah
Steven, I think I understand what Cheetah's saying. To maximize the use of the road force balancer, it might be best to have 4 wheels all the same size AND 4 non-directional tires (asymetric may or may not have any effect). That way, the tires can be mounted at any corner without dismounting tire from wheel, should it be necessary to move them.
As it stands on our cars (and many cars), the road force balancer is the best you can do and better than a mere balance job. I'd still do it in the future, and have in the past.
And btw, I, too, didn't receive a printout on the balancing the last time I had it done. Next time.
Thanks for the explanation, Cheeteah!
Back to the problem at hand, it is probably a big expense to get that other set of tires and wheels balanced and mounted, 96-lt4. And $800 is a lot for shocks! For that, you could get premo Konis and still have lots left over.
Old Aug 19, 2006 | 09:39 AM
redvette6spd's Avatar
redvette6spd
What is road force balancing? My apologies for interrupting.
Old Aug 19, 2006 | 11:02 AM
OldCorvetteFan
This link provides a better explanation than I can ...
http://www.gsp9700.com/pub/features/how.cfm
Old Aug 19, 2006 | 12:14 PM
A95Y's Avatar
A95Y
I was thinking that he could borrow a set of fronts off his buddy's for a test. The best way is to take a set off a car with no problems.
I should qualify my explanation on the GSP9700 to say "high" spot, not "heavy" spot. The Hunter explanation is better than mine. It's still a good machine even if you can't move the tires around. Many guys are too lazy to use the road force system because if there are problems with the tires, it takes more time to move things around to get them optimized. It can still do a conventional balance job. If you don't do it yourself, the only way to know is by the printout. Hope this helps.
To upgrades done=report
Old Aug 19, 2006 | 12:36 PM
Maui's Avatar
Maui
St. Jude Donor '08
My vert used to shimmy like mad before I replaced the nitto's. I could have been bad balancing. I still the get the normal shimmy when I get a bump but much better than before.
Old Aug 19, 2006 | 02:32 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Yeah, but that shimmy is the body flexing, not the wheels or alignment or tires.
Old Oct 25, 2006 | 08:42 PM
Desert1957's Avatar
Desert1957
Default Shocks , Shocks , Shocks!!!!!!!
Hey Guys ,
Just thought I would mention I also have experienced the mistery shake at highway speeds , was ready to buy tires and big balancing when I replaced the front shocks.
Just on a long shot , I thought , come on 17K and the shocks are bad?
Well , guess what they were!
Just think about the explanation of what a shock does?
1.Hold the car up ...WRONG
2.Keeps tires from wearing...WRONG
3.Dampen wheel oscillation...CORRECT
Small and Large harmonics are always happenning on any moving parts , especially front end parts , good quality shocks help squelch all those little pulses out, if your having front end problems and you are sure all the parts are GOOD , try replacing the Shocks , just because they are not leaking oil does not mean they are ok.
Desert
