throttle position senser
Old Aug 14, 2006 | 12:36 PM
dallasknight's Avatar
dallasknight
Default throttle position senser
has and one had to repleace their throttle position sensor. i think mine has went out. because some times after i have been driving my 85 vette and cut it off it will not stay running with out my foot on the gas but after about a 100 yard it's ok.
Old Aug 14, 2006 | 12:41 PM
Pete K's Avatar
Pete K
IF it tests bad, swap it out. Easy to do. It is easy to test with a digital voltmeter.
Old Aug 14, 2006 | 12:55 PM
rick lambert's Avatar
rick lambert
fairly easy task, if it checks out right you may want to check your fuel pressure and have the ignition module tested also.
To throttle position senser
