Happy Camper
Old Aug 14, 2006 | 12:54 PM
bacardioil's Avatar
bacardioil
Default Happy Camper
My cars at Blowerworks getting the final tune. Greg had it Dyno'ed Friday, LT4 383 Stroker. 511 rwhp at 6000 and 553 rwtq at 4500. 9psi. Vortech V1-S trim.
Old Aug 14, 2006 | 05:42 PM
AKS Racing's Avatar
AKS Racing
Good numbers! Now get that boost up a bit more, say 15 psi and let's see what she will do.
Congrats,
Aaron
Old Aug 14, 2006 | 05:47 PM
bacardioil's Avatar
bacardioil
Thanks Aaron
That will take a T-trim or E. The S-trim is max'ed out.
That C6 Nice.
Old Aug 15, 2006 | 12:34 PM
lcvette's Avatar
lcvette
bacardioil,
man I read about your setup before, but can you elaborate on the specs of the entire engine setup etc..? 511/517 on 9psi is AWESOME! I am curious as to the cam shaft, we ar ein the process of having another short block built for the silver car and have decided to swap my 355 low compression forged motor into the red car since It will make less power then the turbo setup and I am already pushing the limits of the stock LT4 crank in mine.. while its out we plan on trying the GTP6 cam we have from my dads old build.. it has alot better exhaust duration and lift then the 219/219 cam we are running urrently and I feel the 219 cam is a big shortcoming to the power potential of the car from the huge torque over power difference.
thanks! and congrats man.. I know you are gonna love that car.. 511/517 is alot of f8un street power to play with!
like Aaron said.. pulley her down and turn up the wick.. with your current numbers around 14-15 psi should feel amazing.. I would put you in the 600+ realm!
CHris
Old Aug 15, 2006 | 03:59 PM
86VX1's Avatar
86VX1
very cool.
Old Aug 15, 2006 | 05:35 PM
bacardioil's Avatar
bacardioil
Chris
Sent you e-mail.
Never could have done it without Greg from Blowerworks.
Its his car and magic, till I get it back. Greg like I say your the man and friend.
Gene
Old Aug 16, 2006 | 03:40 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Default Gene's Genius
I wish I could take credit for Gene's ride, but I can't! All I did was give it a good tune. Gene spent many hours, days, weeks investigating each component of his 'system'. In fact, that's how we met: He liked my Gen IV Gaseous InterCooler system. Gene thoroughly researched every single component of his ride from shocks to cam to his 4L80E transmission. I thought he was crazy for cramming a 4L80E into his Vette, but you know what - he was right! The trans fits beautifully and when combined with the CompuShift controller is the nicest shifting/driving transmission I've driven. The light throttle shifting is silky smooth (no jerking what so ever), and the full throttle shifts are so quick and smooth you wonder how!
Gene's '383' engine is like none other I've ever seen/tested. I still do not know or understand how his engine builder (some guy named Harold) did it, but this engine (with only 500 miles on it) never 'puffed' or 'huffed' under dozens of hard pulls: both on the street and the dyno. This engine seems to have no blow-by at all - never one drop of oil out the breathers or even a little smoke. Usually after a lot of pulls on the dyno I'll see some smoke out the tailpipe, especially when you let up on the throttle, but not here! In fact, when you pull the engine oil dipstick the oil looks exactly like you just changed it - I mean this oil looks like it's right out of the bottle: just clean, clean, clean!
Anyhow, 'cudos' to Gene for all his rigorous research and yes the engine has more in it if combined with a bigger blower.
Best regards, Greg
Old Aug 16, 2006 | 10:13 AM
bacardioil's Avatar
bacardioil
Thank You Greg,
Yes I did put alot of time investigating parts for the engine and it paid off. Harold from Port Pros builds a nice engine. But and I say but, if you have a well built engine, Greg without your Gen IV Gaseous InterCooler System and the time you spend Tuning and the workmanship of the little things done by you, the 511/517 would not be there.
Yes, I did meet Greg when I was interested in his Gen IV Gaseous InterCooler System. At that time the engine was a stock LT1 Vortech V1. I had some of his system installed and Greg finished it up. Greg then asked if he could used the car for his 8 rib system, boy was I lucky. When finished stock Lt1 Gregs complete system 404/403. Do his systems work, Yes THEY DO. So, Thank You Greg
Gene
Old Aug 16, 2006 | 10:17 AM
PortPros1's Avatar
PortPros1
1st Gear
Hello Greg, Gene,
Thanks for the compliments on the motor, I'm happy to hear such high praise from you guys.
We do our best to build clean, good running motors. We have a lot of time invested in bore finish and ring selection. We also go a couple of steps further with our cleaning process. It's nice to hear our customers notice our work and like the final product.
Greg,
From what I've seen and heard from your shop I'd be happy to work with you on any projects you may have.
Gene,
One of the best most well informed customers I've ever had, it's been a pleasure working with you on such a fine ride.
Thanks again.
Old Aug 16, 2006 | 10:24 AM
bacardioil's Avatar
bacardioil
Harold
Your one stand up guy and you stand behind your work. Nice to know people like Yourself and Greg.
Oh yes welcome aboard Harold
Old Aug 20, 2006 | 01:28 AM
Mo_Bandy's Avatar
Mo_Bandy
Gene,
Congratulations, and thanks for letting me have a test drive while I was out there with Greg for a few days...
I saw and agree with everything said about the engine, Harold you did a stand up job!
That car has a very nice shift pattern... smooth as silk... I'm getting close to dyno time with mine as well. I'll keep you posted...
Great numbers Gene!
Old Aug 20, 2006 | 01:46 PM
bacardioil's Avatar
bacardioil
Hi Mo
Thanks, anytime.
Sure your going to get some great #s with your beast two.
I have to agreed with Greg and you on Harolds build, Harolds, a stand behind his work guy. Harold keep up the great work.
Gene
To Happy Camper
