[LT1] Cannot set Minimum Air (idle)
Old Aug 15, 2006 | 01:13 PM
Lone Ranger's Avatar
Lone Ranger
Default [LT1] Cannot set Minimum Air (idle)
Tried to set minimum air for idle the other day, 1995 model, had problem. Ran through the procedure as follows:
1. Grounded diagnostic pin (4 to 12) on ALDL (16 pin OBDII style ALDL)
2. Key-on to park IAC pintel to closed position
3. Wait 30 seconds, pulled power plug to IAC while key-on
4. Started engine
Problem was that it idled @ 1500 rpm upon starting up after step 4, and even adjusting the throttle plate idle screw until the plates were all the way closed made no difference, idle remained @ 1500. This has to mean the IAC stayed wide open and did not close.
Why is this?
Old Aug 15, 2006 | 06:49 PM
merlot566jka's Avatar
merlot566jka
is it clean? does the sensor have over abundant carbon on the pintal? just things to check
Old Aug 15, 2006 | 10:39 PM
Lone Ranger
It was cleaned about 15,000 miles ago.
Old Aug 16, 2006 | 09:57 AM
Susan_5's Avatar
Susan_5
did u make sure the o-ring was on the iac when you put it back on? some come with gaskets, others with o rings. i used both just to be sure. other than that the only other thing i can think of is checking the wiring to the sensor, or actually take it out and conduct your test again and watch to see if it moves properly.
what does it idle at normally?
Old Aug 16, 2006 | 09:59 AM
merlot566jka
thats my mistake, thats my fiances profile. i didnt realize i was signed in on her name!
Old Aug 16, 2006 | 10:05 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Did you remove the TPS sensor?
If so, get two paper clips, straighten out and slide into the end of the TPS sensor connector, A (earth) and B (tps output), keep the wires separate and turn the ignition on (car off) and measure the voltage with a DIGITAL MULTIMETER at the wires and adjust by loosening the torx bolts, if necessary, to 0.54 volts - this is the normal idle setting.
Old Aug 16, 2006 | 10:06 AM
Aardwolf's Avatar
Aardwolf
4. Started engine
Why is this?
Mine does exatly the same thing. I checked the counts of the IAC on a scanner and it looked fine. It could be that the sensor reports to the computer that it is moving but it really does not? Also it could be an air leak. Is your car running rich, mine is.
Old Aug 16, 2006 | 10:09 AM
Aardwolf's Avatar
Aardwolf
Just a quick note, if your car is stock without the coolant bypass mod, it may be easier to make a socket for the IAC. Or maybe a crows foot would fit. If you decide to check the sensor. I took a spare socket, threw it in the vice, and ground on it till it fit. Maybe a cheap thin wall socket would just fit. The socket I ground on can remove the IAC with no problem. Easier then removing the TB in some cases.
Old Aug 16, 2006 | 12:46 PM
Lone Ranger
My IAC is secured to the TB via torx bolts.
Old Aug 16, 2006 | 12:48 PM
Lone Ranger
TPS is .55volts, this is via Datamaster readout w/ key on but engine off. IAC counts (key on engine off) show to be 120 on datamaster, but I've got some sort of problem with the AKM cable and my ALDL, because I can only get data when the engine is not running.
If I start the car with Datamaster running on the laptop and the AKM Cable hooked up, the Service ASR light illuminates and the car shuts off. It stores a code in CCM module 9.1 for Serial Data Link Error (H72) afterwards. This (H72) only happens when I try to log data with datamaster connected and the engine running. So I can't get my IAC counts for when the car is idling
To [LT1] Cannot set Minimum Air (idle)
