And Never EVER Feed Them After Midnight.....
So now it wouldn't start today as I went to leave work today. My ECT sensor is now also stuck at a high voltage. Are these two related? Is there a ground wire I need to clean and fix or is this just a weird coincidnence and I should just rewire both sensors and hope it doesn't happen again??
I'm running an Accel Gen 7 DFI so when they get stuck high it defaults to -40* for the IAT and 50* for the ECT. Which dumps a bunch more fuel into the car and makes it very hard to start, luckily the air temps cooled off enough tonight to let me get it started and get the thing home.
+5V --- Wire 1 --- Sensor --- Wire 2 --- ECM Read --- Ground
If I disconnect the sensor and read the voltage at Wire 2 on the sensor side it should read 0V if everything is working properly. But even with a bad ground it should be a floating voltage, but still not exactly 5V (actually 4.x v). Wouldn't there have to be a short to the 5V supply somewhere? I'm going to check the ground wires anyways and see if that helps, it may just be that Saturn's moons areinline with something.
+5V --- ECM Read --- Wire 1 --- Sensor --- Wire 2 --- Ground
All that was wrong with my ECT sensor was that it was unplugged, but the ecm still read 5V. So I'm guessing the ecm read is just a current read that converts to a voltage.
As for the IAT, I ended up taking the ecm out and looking at the connections there, but I didn't see any problems and then I took the voltage readings at the plug and they seemed normal, 5V and 0V. So I tried an extra sensor I had lying around and it worked just fine. But I SWEAR I checked the voltage at the plug before and it was 5V on both sides. I guess all that matters now is that things are fixed and I can get some stress relief with some quick 0-60 runs.
I havent seen thr movie in a while though, I may be wrong.
