Stalling
Old Aug 15, 2006 | 11:54 PM
vettecruiser7's Avatar
vettecruiser7
1st Gear
Default Stalling
Every once in awhile my 1988 will stall while slowing down for a light or stop sign. It usually happens several times in a row until it somehow corrects itself.
Old Aug 16, 2006 | 12:52 PM
SunCr's Avatar
SunCr
Kinda like turning off the key only you didn't! I'd suspect it's losing the reference signal from the distributor and it won't fire the injectors without it. So see if it's rich or lean first (to rule out the MAF) or if there's a big electrical surge from something like the fan cranking up as you roll to a stop. If not, I'd replace the ignition module and pickup along with making sure that the 4 wire harness from the distributor doesn't have any nicks or abrasions in it.
Old Aug 16, 2006 | 03:53 PM
VenkmanP's Avatar
VenkmanP
Try posting this in C4Tech and you will get a wider audience.
To Stalling
