Would I gain anything
Old Sep 7, 2001 | 10:42 PM
1Slomofo's Avatar
1Slomofo
Default Would I gain anything
by just porting the heads on my 86 Alum? Valve Job? Port intake?
etc thanks.... Or do I have to do a bunch of other crap to have any effect?
Old Sep 8, 2001 | 04:46 AM
1Slomofo's Avatar
1Slomofo
Default Re: Would I gain anything (1Slomofo)
No replys??
Old Sep 8, 2001 | 04:53 PM
GlockLT4's Avatar
GlockLT4
You should see a gain from porting and polishing any heads. Of course it depends on how well the job is done. You definitely want to do the intake ports as well though because you're only going to flow as best as the most constricting part of the intake. While you're doing that, put some better springs on as well as 1.6 roller rockers.
[Modified by Glock'94, 2:54 PM 9/8/2001]
Old Sep 8, 2001 | 07:04 PM
smallblock's Avatar
smallblock
you would need to open up the rest of the intake system( port plenum and base, install large tube runners) and also install a freer flowing exhaust
To Would I gain anything
