Any ideas would help
Old Aug 17, 2006 | 01:52 PM
beat1970s's Avatar
beat1970s
Cruising
Default Any ideas would help
I have a 1985 5.7 TPI. My wife and I took it out for lunch, it ran great. When we came out from the eatery the power windows did not work. I figured it was a fuse. Then the cooling fan would not work and when I went to turn it off I could not turn or get the key out of the on position. I have checked all fuses and they are fine. Before I start on my long journey of trying to find a elctrical short, does any one have any ideas on what it might be or where to start.
Old Aug 17, 2006 | 02:07 PM
jimmers's Avatar
jimmers
I hate electrical problems! Someonw will chime in with more knowledge then I have about them.
Old Aug 17, 2006 | 04:11 PM
toptechx6's Avatar
toptechx6
Sounds like a problem with the ignition switch. I believe it is located near the bottom of the steering column and connects to the key switch with a linkage rod. Sometimes the attaching nuts come loose and it gets out of adjustment, could be as simple as that. I would start by looking there, good luck.
Old Aug 17, 2006 | 04:41 PM
beat1970s's Avatar
beat1970s
Cruising
I will thank you for the reply.
Old Aug 21, 2006 | 10:01 PM
beat1970s's Avatar
beat1970s
Cruising
Juat wanted to say thanks for the place to start. The igniion switch had a short. You saved me from a long journey through the wiring.
Old Aug 22, 2006 | 07:33 AM
toptechx6's Avatar
toptechx6
You're welcome, thanks for your reply. Sorry to hear your key/linkage is still a problem, good luck.
To Any ideas would help
