383 combo questions cam?
Old Aug 18, 2006 | 08:19 PM
c4mo's Avatar
c4mo
Default 383 combo questions cam?
ok to start with the car has 3.08 gears and is a 85' my plan is a all forged 383 with around 10 to 1 comp. I already have afr 195 heads accel base manifold with tpis runners and ported pleunum with 58mm tb or super ram with lt headers dual exhaust, now my cam choice zz9 which i have or a lpe 219 cam this car is mainly street driven so what do ya think also what hp are you thinking thanks
Old Aug 18, 2006 | 09:12 PM
vader86's Avatar
vader86
So let me translate your post into something legible....
You are planning on a 383, forged assembly, and shooting for 10:1 compression.
You already have longtubes and true duals on the car. You have AFR 195 heads and the Accel base already, and have TPiS runners with a 58mm TB on the car now, correct?
You do or do not have the SuperRam sitting in a box?
If you go with SR, then 219 is where I would go with a 383. ZZ9 is too small for that. With 219 it should make roughly 450chp.
If you stick with the TPI setup as it is, then ZZ9 or 211 would be fine.
Old Aug 19, 2006 | 01:06 AM
sami85L98's Avatar
sami85L98
Great advice from vader86. I love my 383/219 cam/dart 200cc heads/10.7 comp/......
Old Aug 19, 2006 | 08:24 AM
c4mo's Avatar
c4mo
Default cam
Sorry about the misunderstood info, i wasn't sure of the 219 cam because of my rear gear. All the parts are not installed except the exhaust, but are laying around. Is there a better choice cam for my chosen combination? How is the superram on lowend? With my computer tuned where do you think the engine will make its power? thanks agian
Old Aug 19, 2006 | 10:45 AM
tequilaboy's Avatar
tequilaboy
For a 383, I'd be thinking something in the 230/236 duration @ 0.050 range.
Something like the cam in this article:
http://compcams.com/Community/Articl...?ID=1737510521
Old Aug 19, 2006 | 11:28 AM
jimmers's Avatar
jimmers
Old Aug 19, 2006 | 11:41 AM
vader86's Avatar
vader86
Its very similar to TPI but with much better midrange and top-end ability.
To 383 combo questions cam?
