Going TH-350
Old Aug 19, 2006 | 02:08 PM
honda hunter's Avatar
honda hunter
Default Going TH-350
My mind is set but my question is who can I talk to to figure out the best stall and gear for my setup? I was thinking of something like 4000 stall with a 3.xx something gear. Mods are:
-Engine-
Eagle 4340 383 stroker kit
SRP -5 cc pistons
Upgraded oil pump
Vented Optispark conversion (Dynaspark)
Cloyes Double Roller Timing chain
LT4 ported intake manifold
Canton oil pan
Meziere electric water Pump
AFR 190 Lloyd Elliot port and polished 217cc heads
HEAD FLOW NUMBERS
.2 138/107
.3 194/143
.4 242/178
.5 274/199
.6 285/211
.650 288/214
23X/23X/10X custom cam
Comp 977 dbl springs and Ti retainers
Crane energizer series non slef aligning Rocker arms
AFR guide plate
AFR one peice chrome moly pushrods
Racetronix 37lbs injectors
Racetronix fuel pump
Taylor spark plug wires
Hypertech 160 thermostat
BBK 58mm Throtle Body
K&N filter
Hooker long tube headers
Flowmaster exhaust
X pipe 3" pipes
MSD 6AL ignition
MSD blaster coil
4 bolt block
NGK TR6 Plugs
PCMforLess tune Alvin
Old Aug 19, 2006 | 06:05 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It will all depend on what you plan to do with the car. If you plan to do much street driving, I'd rethink the TH350. The 700R/4L60/4L60E can be built plenty stout and you'll still have OD for mileage. I have a 3000 stall Vigilante (with a 3.07 rear) and wouldn't really want anymore converter for the street. That being said, I put a lot of miles on mine including long trips.
If you're just building for ***** to the wall performance, what the hell....
Old Aug 19, 2006 | 06:09 PM
honda hunter
I'm looking for ballz to the wall performance but it will be a DD. I live on a small island. The longest trip I make only takes 20 minutes with little highway miles. I dont fear the gear nor do I fear a big converter in the name of performance. I just want the right setup for what I have.
Old Aug 19, 2006 | 06:19 PM
NitrousSam's Avatar
NitrousSam
Default Th-350
Contact Ski_dwn_it on here. He made the switch from a 700R4 to a TH-350 so he should be able to give you some good advice and his car is plenty fast.
Old Aug 19, 2006 | 06:20 PM
honda hunter
I'll send him a PM. Thanks.
Old Aug 19, 2006 | 07:08 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Yes the swap is VERY simple. Give me a PM and I can share the details.
NitrousSam....what are you talking about "plenty" fast for.....IT'S NEVER FAST ENOUGH!
Old Aug 19, 2006 | 07:15 PM
honda hunter
PM sent
Old Aug 19, 2006 | 07:34 PM
NitrousSam's Avatar
NitrousSam
Your car is plenty fast especially for a car that can be driven on the street!!! You are going to like my 84. Lightweight and it should have one major top end charge.
Old Aug 20, 2006 | 08:59 AM
Casethecorvetteman's Avatar
Casethecorvetteman
You got a DANA 44 ready to go in it yet Hunter?
Old Aug 20, 2006 | 09:17 AM
honda hunter
I found one here for around $1300. Comes with a spool and some 4.5x gears. It was in a vette that ran 9's so I'm sure itll hold. When the owner gets back from vacation I should be able to seal the deal I hope.
Old Aug 20, 2006 | 09:44 AM
Casethecorvetteman
Good stuff!!
To Going TH-350
