1989 idles up and down
Old Aug 19, 2006 | 05:02 PM
culuknn2's Avatar
culuknn2
Default 1989 idles up and down
when i first start the car it runs normal but after it runs for a few minutes the rpms go from 500-700 up and down.i replaced the iac because it kept stalling and that fixed it from stalling.so what could be causing this to happen?
Old Aug 19, 2006 | 05:06 PM
RRT vette's Avatar
RRT vette
What engine temp does the engine get too when this happens?
Is the SES light on? Any codes?
Sounds like a vac leak...
Old Aug 19, 2006 | 05:37 PM
rick lambert's Avatar
rick lambert
DOES SOUND LIKE A VAC. LEAK.
Old Aug 19, 2006 | 08:33 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Aug 19, 2006 | 09:58 PM
shilly's Avatar
shilly
I am pretty new to the forums and had my vette a little over a month, so senior members/owners, correct me if I am wrong...
culuknn2,
To find the leak, get a can of carb cleaner with the thin hose that attaches to the nozzle. Then while the car is running, spray the end of each vacuum hose one at a time. If you hear the engine rev higher after a spray, that's where the leak is. Don't stop though, keep checking, you may have more than one leak.
Old Aug 20, 2006 | 01:02 PM
culuknn2's Avatar
culuknn2
thanx for all the help
Old Aug 20, 2006 | 01:09 PM
rick lambert
Pretty close shilly, thing is you have to check the entire length of the vac. lines, not just the ends, our plastic vac. lines are formed, and personally I found a line cracked in one of its curves. And it's a good idea to check for vac. leaks on the intake as well.
Old Aug 20, 2006 | 01:33 PM
87 rag's Avatar
87 rag
My problem was similar. Leak was at the drivers side runner by the cold start. WD40 works too or a not lit propane torch.
To 1989 idles up and down
