Replacing Opti Procedure?
Old Aug 21, 2006 | 03:29 PM
mjfox's Avatar
mjfox
Default Replacing Opti Procedure?
Do you have to remove the radiator to get at the opti like it says in the corvette fever article seems unneccessary.Also I replaced my water pump 3 years ago think its ok to keep in .
Thanks Mike
Old Aug 21, 2006 | 04:46 PM
Vetracr's Avatar
Vetracr
No need to remove radiator to replace opti, just the water pump.
Larry
Old Aug 21, 2006 | 05:46 PM
wayne lowry's Avatar
wayne lowry
What are they nuts ? The radiator does not have to come out to change the opti. The damned crank pulley has to come off and that's the only real p.i.t.a.
Old Aug 21, 2006 | 06:40 PM
mjfox's Avatar
mjfox
Default New Or Rebuilt Opti
What is the way to go new opti $1000 can gm or rebuilt $325 can car quest
what do you think.
Thanks Mike
Old Aug 21, 2006 | 06:43 PM
clf93lt1's Avatar
clf93lt1
call this place http://www.superchevyperformance.com...s/10457702.asp
Old Aug 22, 2006 | 06:37 AM
pcolt94's Avatar
pcolt94
I would personally not buy a rebuilt. Have read articals saying is ran for awhile and the problems came back. Probably for almost the same money you can get a new one anyway and lots of buying options. It's to much work to do 3 months later a second time.
Old Aug 22, 2006 | 08:45 AM
runner140*'s Avatar
runner140*
Do not try to save money here (on the Opti). Buy a new Opti from your favorite GM, AC Delco seller. I use "GMpartsDirect" or "Superior Chevrolet".
Old Aug 22, 2006 | 11:19 AM
SJW's Avatar
SJW
Your profile suggests that you're talking about a '92. I'd STRONGLY encourage you to NOT install another OEM Opti in your '92. The '92 used the deficient first-generation Opti, and a replacement unit will be as deficient as the one you're removing.
Consider the DynaSpark as an aftermarket solution that should serve you much better than the OEM replacement. Alternatively, MSD has a new-to-the-market Opti replacement that looks good, but lacks the time-in-the-field record that the Dyna has established.
If you have a good set of general mechanic's tools, and decent mechanical skills, you can tackle the Opti swap yourself. No special tools are required. There is no reason to remove the radiator to do an Opti swap.
Here are a few tech tips I wrote up some time ago about doing an Opti swap:
Get a Factory Service Manual, and follow the procedure it lays out.
A few tips (I'm going from memory here, so I'll probably forget a few things):
Drain the cooling system.
Disconnect the MAF sensor and IAT sensor and remove the air intake duct with the MAF and IAT as an assembly.
Disconnect the ECT sensor and remove it from the water pump.
Remove the serpentine belt and tensioner.
You may find that you’ll need to unbolt the coil/ICM bracket from the front of the right cylinder head. I can’t recall for sure whether or not I did.
Unbolt (but don't remove) the power steering pump. This will help you to sneak the new plug wires in/out behind the pump, but may also be somewhat helpful when working on the water pump/Opti.
If you want more room to work, you can remove the radiator, but it isn't strictly necessary, and it involves considerably more work to remove it (I left mine in place).
The FSM will tell you that you need a special Kent-Moore puller to remove the crank pulley/damper. You don't. Here's how to get it off:
1. Raise the front of the vehicle enough that you can get under the car (it's also helpful to have it at a more comfortable height while you're working from above).
2. Remove the three bolts that secure the pulley/damper to the hub.
3. Mark the damper and hub so that you can easily see how to realign them to each other later.
4. Slide under the car with a long pry bar or hardwood dowel (I use a jumbo Snap-On screwdriver that's around two feet long) and a mallet.
5. Place the tip of the pry bar against the rear face of the damper, as close to the hub as possible (Ideally rest the tip alongside of the hub).
6 Give the pry bar a few whacks with the mallet, and with any luck the damper will pop off without too much of a fight.
You may find it helpful to apply a few whacks, then rotate the crankshaft in 120* increments, whacking it a few times at each interval (I haven't needed to do this).
It's also helpful to, if possible, shoot a bit of penetrating oil where the damper meets the hub, a day or more in advance of doing the job.
After you get the damper off, clean the damper/hub mating surfaces to remove all corrosion, etc, and apply a very thin coating of anti-sieze compound to these surfaces before you reassmble the damper to the hub. This should make it a lot easier to get the damper off next time.
Once the damper is removed, rotate the crankshaft so that one wing of the damper hub is at the six-o'clock position. This will position the other two wings at around the ten- and two-o'clock positions. In this orientation, the Opti will clear the hub as it is being removed/installed.
The Opti basically unbolts and pulls off as you'd expect, once you have the water pump and damper out of the way.
Once the Opti is out of the way, inspect the shaft seals for the Opti, water pump, and crankshaft. If they show any signs of leakage, replace them now.
When you install the new Opti, be sure to align it correctly with the cam gear, and don't force it into place against the timing cover (do NOT use the bolts to draw it into place). At most, give it a gentle bump with the heel of your hand to encourage it to pop into place.
Reassemble everything else.
Follow the cooling system refill procedure in the FSM carefully, and you'll have no problems with this. In particular, be sure to bleed the air out of the system as it's being refilled.
Hope this helps.
Be well,
SJW
To Replacing Opti Procedure?
