Locked in start
Old Aug 21, 2006 | 04:01 PM
beat1970s's Avatar
beat1970s
Cruising
Default Locked in start
1985 5.7 TPI automatic. I can not turn the key off. I have removed the ignition switch and still can not move the key from the start position. Any ideas would help.
Old Aug 21, 2006 | 05:17 PM
toptechx6's Avatar
toptechx6
You will need to remove the steering wheel to inspect the lock cylinder and rack mechanism that connects the key cylinder to the switch, additional column disassembly may be necessary. It can be an intimidating job the first time you do it, there are lots of parts and some special tools required. At the very least get a factory service manual before attempting it, even better would be help from someone who has been there before. Wish I had an easier answer, good luck.
Old Aug 21, 2006 | 09:56 PM
beat1970s's Avatar
beat1970s
Cruising
I will thanks again.
Old Aug 22, 2006 | 11:17 AM
jadedvette's Avatar
jadedvette
Chech the ring on the steering column in back of the key switch were a column shifter would be. If this ring is moved out of position, the key can't be removed.
Good luck,
Joe
To Locked in start
