In or Out
Old Aug 21, 2006 | 11:55 PM
Coconut's Avatar
Coconut
Default In or Out
Does anyone know if the A/C - Heater blower on a 1991 Corvette is supposed to blow air through the top of the outside air vents, or is air supposed to be sucked in through them?
I noticed today that the air is blowing out the top of my vents.
Old Aug 22, 2006 | 01:14 AM
bogus's Avatar
bogus
air gets sucked in from the cowl, or, from under the dash.
check under the hood, I will bet $$ you have a broken vacuum line... check under the left headlight, and over on the right side of the manifold.
Old Aug 22, 2006 | 09:28 AM
Coconut's Avatar
Coconut
Default Thanks
I thought it was supposed to suck in. I've checked the lines, & everything seems to be ok; However, I found one vacuum line that I can't check. I'm pretty sure it goes to the A/C. It dissappears behind the back of the distributor. Does in go into the firewall, or reroute over to the washer pump?
That's the only line I haven't checked, so it must be that one? If you can tell me where it dissappears to, I'd appreciate it, so that I can check it. Thanks!
To In or Out
