Need to disable courtesy light timer, where is it?
Old Aug 23, 2006 | 01:58 AM
MrRenoman's Avatar
MrRenoman
Default Need to disable courtesy light timer, where is it?
On a '85, I know its under the dash on the passenger side. It may even be taped to the harness. But I have looked a couple of times by removing the lower panel and can't see it. Anyone have a pic or a detailed description of where it is exactly? I have the Helms and it shows it but I can't see it. The timer is just flashing the lights quickly. Looks like all I can do is bypass it. Any help appreciated.
Art
Old Aug 23, 2006 | 02:24 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Book shows it taped to the top side of the main harness behind the breadbox, maybe 6-12 inches away from the fuse panel.
Looks like a tough place to get to. I don't see any way of cutting power to it either, everything is buried.
Old Aug 23, 2006 | 03:28 AM
morgan_kane's Avatar
morgan_kane
I think you must take dash away, then it is easy to see. In my -87 it is taped to harness behind pass side air pipe.
Old Aug 23, 2006 | 11:24 PM
MrRenoman's Avatar
MrRenoman
Found it. What a pain, it wasn't buried really deep just taped to the harness under the breadbox next to the computer. I just spliced the 3 white wires together. Good for now...
Thanks,
Art
To Need to disable courtesy light timer, where is it?
