B&B Tri-FLow Install...
Do the mufflers brackets have to be grinded down to fit on the mufflers? They seem to hit one of the tips.
What size (thread/pitch) are the bolts that the muffler brackets bolt to? I was just at a hardware store with the mufflers and none of the bolts seemed to thread on correctly.
Is the resonator directional?
So far I have hung the front and rear pipes along with the resonator. It seems that the left rear pipe is up against the rear but I think it will go lower once the mufflers are on. The front left pipe is up against the hanger and it has no movement, how do I correct this?
Thanks in advance,
Dave
2) not sure on the bolts. My guess is you will find something or just tap a proper fit.
3) The resonator IS directional. I I recall, as the exhaust passes through the resonator, the "fin openings" are towards the rear.
4) I needed to get shorter exhaust hanger springs. I believe I got 1 1/2"
Got to love "bolt-ons"
