Clogged Cats
http://forums.corvetteforum.com/show....php?t=1466770
Unhooked EGR tubes (suggestion from another member) and I
got a positive response almost like it wanted to fire. Is this enough
of a pressure relief in the event of clogged cats or should I drop the
exhaust from the manifolds to eliminate any doubt? Just curious,
what kind of pressure should I get at the exhaust tips while cranking?
This is a lame question but i dont feel much of anything back there
while Mama cranks the engine for me?
-Was getting Code16 (bad Opti)
-Brand new MSD Opti (Getting spark at all cyls.)
-Quadruple checked plug wires
-New Plugs
-Brand new Ford injectors 24#
-NOID test: Pulses at all injectors
-New fuel filter
-Siphoned and replaced fuel
-Fuel pressure:43lbs (will hold all day)
-New ICM & Coil
-Swaped ECM with a known working ECM
-Snap-On scanner shows no faults or codes
-VATS disabled
-Cranks But no start, Will sputter out the intake
only after cranking. Never a reaction while cranking?
-MSD Tech says: "If your getting spark the Opti
is not defective."
If that doesn't succeed, something else worth trying would be to remove the plugs and squirt a small amount of engine oil in each cylinder (similar to running a wet compression test) with the plugs still out disable the ignition to prevent a fire and crank the engine briefly to distribute the oil, then reinstall the plugs, enable the ignition and try to start. Cylinder walls can get washed of oil after extensive cranking and lack compression. Again this costs nothing but your time.
I didn't read the entire first post so forgive me if this has been covered but how about the timing chain? Good luck.
Second, I've been wrenching for over 45 years, and I know the first thing I'd do, since it really sounds like a timing issue..at least to me. I'd pull the valve cover on the drivers side,pull the #1 plug, rotate the engine until both valves were closed and then check to see where the rotor was pointing..I actually have used a drinking straw inserted in #1 and rocked the engine to make sure I was as close to TDC as possible.
You know, when we run into problems after we've worked on something we need to double, triple check what we've done. I actually did a port job on a friends old ford, put it back together and...to make it short (chevy minded) I put all the plug wires in a clockwise rotation on the dist. it ran
like poop, when the light came on, I finally realized the at least old fords the rotator turned counter clockwise. Duh.Just trying to help here. Seems like thoughs with Opti experience agree that it can't be installed 180 out....but God, I'd have to check it just to be 100% positive, since you've put in so many new parts. BTW, is this a new or rebuilt Opti?
I agree, drop the exhaust, prove us all wrong!!!
I guess it is possible, but if the cats are SO clogged, then would they rattle? I mean, they would have to melt into a plug of goo to do that... it would be exceptionally rare.
RetroTA, I see where you mentioin you have steady fuel pressure, signal to the injectors, spark, but didn't see where you confirmed getting air. As Rick stated, make sure your in time and the wires are on the right cylinders.
after that I would recommend a trip to the local chevy dealer on a flatbed and let them worry about diagnostics..
My 200,000 beater 1993 Camaro melted the cat into a big glass marble last week. Yes, it definitly rattles, but it still runs just fine. Lost a mpg or two, but no other big change. That being said, Yeah, I agree one could still cause a no start condition, it's just not a very common occurance. And yes, I'm going to fix it, the rattle's driving me nuts!
. I know where a fairly low mile one is in a junkyard, just can't get there till this weekend.
. I know where a fairly low mile on is in a junkyard, just can't get there till this weekend.runs and no start? Had a Chevy mechanic check it out and his
best guess is a defective MSD Opti! He said at the dealer thats
where he would start. Is there a way I can check the timing
of the Cam/Crank while I have it apart? Im thinking I can check
the solid spline on the Opti drive pin to the arrow on the crank hub?
Both at noon on a factory LT1?
