Low Coolant Light
The light only comes on under acceleration, when the motor goes above 1900 RPM. It will shut back off when I reach cruising speed (< 1900).
I have been checking pretty closely for leaks, and had not found any until last week (showed up real good on my parent's new driveway :( ) There were 2 small drops under the front of the car on the passenger side. After further inspection, I found some white specks on the underside of the hood right above where the upper hose connects to the radiator. I also found a few white drip marks right around where the host connects. I could not see anywhere it was split. The clamp was a bit loose, so I tightened it down.
I've checked the coolant level since I've had the problem. The level has not really appeared to go down at all. I've also noticed that the coolant level doesn't really fluctuate much, whether hot or cold. The hot and cold line markings on the reservoir would make me think that this should not be.
The only guess I have is that there is a small leak around the upper hose is inhibiting the vacuum effect of the coolant being pulled from the reservoir under acceleration. I would also like to find out where the sensor is (can't seem to find it in Haynes) so I can check that as well.
One other thing...the car runs about 4-6 degrees cooler on the highway :confused: My operating temp seems to be fine, between 188 -192 on the street and 196 - 198 on the freeway. I've currently go a 160 deg stat and the fans adjusted for 180.
Sorry for the long description, but I figured if anyone could help it would be you all
What do you guys think??Thanks,
Scott
That should be it... Have to fill it open and at temp and stopped mine so assume it will yours too...
Thanks,
Scott
[Modified by Hurricane_777, 1:17 AM 9/10/2001]
