Lets delete some equipment
Old Sep 9, 2001 | 06:28 PM
jeffie86/96's Avatar
jeffie86/96
Default Lets delete some equipment
OK heres the deal, I got the engine tore down to just the heads and block. I want to know if I can lose the tube that goes to the pass side exhaust manifold from the intake( there is some kind of sensor plugged into it)? also can I lose the AIR tubing and valves without the computer going TILT?Emissions are not a factor . :smash:
Old Sep 9, 2001 | 07:02 PM
GlockLT4's Avatar
GlockLT4
Default Re: Lets delete some equipment (jeffie86/96)
I believe you are talking about your EGR system. I'm not sure if you can eliminate that easily. Computer controlled cars like to have that left on. Nothing a little computer programming can't fix though! :D
Also, check here .. http://forums.corvetteforum.com/zerothread?id=147679
[Modified by Glock'94, 12:12 AM 9/10/2001]
