Hub Bolt Tourqe
Old Aug 29, 2006 | 06:39 PM
85redinside's Avatar
85redinside
Default Hub Bolt Tourqe
I'm sure this has been asked before but, what is the tourqe on the 3 bolts that hold the rear hub in place (the t-55's)? I have looked everywhere but can't find anything I can depend on.
I have an '85
Old Aug 29, 2006 | 07:00 PM
CFI-EFI's Avatar
CFI-EFI
Did you look at the end of chapter 3, rear suspension, in your FSM, where all the rear suspension torque specs are given? Mine says 59 to 73 ft. lbs. You might want to make sure your isn't different.
RACE ON!!!
Old Aug 29, 2006 | 07:14 PM
bogus's Avatar
bogus
And there was a revision somewhere down the line, the big bolt is now torqued to 200ft lbs.
Old Aug 29, 2006 | 07:33 PM
85redinside
Which big bolt is now torqued to 200 ft lbs?
Old Aug 29, 2006 | 07:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The large axle nut.
59-73 lbs for the 3 torx bolts holding bearing unit to knuckle
Old Aug 29, 2006 | 07:42 PM
85redinside
That's what I thought he ment.
THANKS EVERYBODY FOR YOUR HELP
To Hub Bolt Tourqe
