L98 Performance Expectations?
Old Aug 31, 2006 | 08:14 PM
UDLOOSE's Avatar
UDLOOSE
Default L98 Performance Expectations?
So I've done a bunch of mods as noted below, and I am wondering how much HP/TQ I could expect from the combo. I used one of these accelerometers which told me I was running around 275 RWHP. Albeit I have a slipping clutch, maybe as a result of increased power, however HP still seems low.
Looking for opinions. Thanks
Accel Superram Plenum Ported and Polished
Accel short tube runners Port Matched
Accel Lower intake manifold Port Matched
BBK 58MM TB
Edelbrock 60879 heads including roller rockers Ported, & Milled 0.020"
Accel 26# injectors
BBK adjustable fuel pressure regulator @47PSI
No emissions i.e. no air pump or EGR,CATS
Headman Hedders, long tubes
De-Screened MAF
No cats, and 2.5" dual exhaust with x-over.
11.1 Comp
MSD Ignition
Comp Cams Duration 234/244, Valve lift 498/500, Lobe angle 112
Custom Tune By Jesse Azzato
Air Cleaner Lid opened up
Old Aug 31, 2006 | 09:10 PM
vader86's Avatar
vader86
If something is hurting the top end power numbers, its probably those heads. Out of the box they are 165cc correct? Even ported I wouldnt think they'd be quite adequate for the rest.
Old Aug 31, 2006 | 09:41 PM
tequilaboy's Avatar
tequilaboy
This is only a guess, depending mostly upon the heads:
300-320 rwhp
340-350 lb.ft. rw torque
Are you hitting the MAF flow limit at 255 gm/sec? If not, I'd say your under 300 rwhp.
Old Aug 31, 2006 | 09:48 PM
jonecap's Avatar
jonecap
300-320 rwhp
My stock heads/cam '90 made 277 rwhp with a similar set up to yours...less the heads & cam of course. I'd guess your're probably slightly over 300rwhp.
Old Sep 1, 2006 | 01:51 AM
Demonic85's Avatar
Demonic85
If you build up the engine, new better flowing heads are an absolute must on L98s. 165 cc is crappy, look for something over 200 cc.
Old Sep 1, 2006 | 06:23 AM
UDLOOSE's Avatar
UDLOOSE
300-320 rwhp
I think I am, I keepm getting a code 33, high grams a second. I'll post some data from the TTS data master for you guys to review.
I think I might need better flowing heads as most of everyone mentioned.
Any recommendations on the type of heads that would work with the rest of the parts.
Cheers
Old Sep 1, 2006 | 07:46 AM
88BlackZ-51's Avatar
88BlackZ-51
Cheers
if your edelbrock's are ported. they are prob more then enough. only way to tell is get them on the flow bench.
Old Sep 1, 2006 | 08:29 AM
mseven's Avatar
mseven
Based on what?
While I agree better flow would help, going over 200 on a 350 would be overkill. Bigger doesn't make it better !!
Old Sep 1, 2006 | 09:14 AM
vader86's Avatar
vader86
No, with a 350, 180-195 would be fine. Over 200 should not be needed with a SR engine until you go really big in cubes, like a 406, its not required on a 383.
To L98 Performance Expectations?
