A friend recently flowed them and got 263/188 at .600 lift. I will be prob be buying a set for my dad's car. They fit perimeter and centerbolt as well.
You may want to call Summit & inquire about a set of heads for your application. I would ask who makes their brand of heads(200 cc intake ports, 64cc combustion chambers, 2.02"/1.60" valves. $995.95). For the money Trick Flow does make a good set of heads.
i own a set of tfs heads. but for $750 those heads are a deal, anyway u slice it.
What do any of you think of the Trick Flow top end engine kits? Looks like fairly reasonable prices at Summit (around $1600.00). Was thinking about the TFS-K314-420-395 for a 355 or possibly a 383. How does that cam look for those applications.
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by 86VX1
first give us a budget that you are willing to spend, we already know that you do not want to spend the 2k on heads. for about a 1000 you can get a lot of head for the money.
i agree with Vader and tequila boy.
Just got back from a long weekend.
I am trying to formulate a budget. I don't mind dropping $2K on heads, however, is it really NECESSARY?
I don't want to cut myself short, and I am not trying to do it CHEAP I am trying to do it right, cheaply.
Originally Posted by RacerX70CC
Edelbrock heads are priced EACH not by the pair. The cylinder heads are the most important parts of your engine, and you need a camshaft to match them. Simply "throwing" a set of aftermarket heads is no guarantee you'll make any more HP than stock. Also, basing your build on price only is not a good idea either. If you're bucks down, keep an eye out on the forum for good used pieces, but have your bucks ready to go...
Good luck!
I am not "throwing" heads at it. It's one of those things that "while I'm at it" disease.
I really don't want to do the cam, with the motor in the car it's just a bitch. I WILL do a cam at some point in the future, just not today.
SO here is what I'm hearing.....
Nothing wrong with the Edlebrock for the money. AFR are pretty well respected and for the set they are about $300 more. I read somewhere here on the forum with some fit and finish problems with Trickflow. One guy about a year ago had some real problems with them.
There are some other heads to consider as listed in the thread.
I just got back and have to go through this.
Thanks for all the input.
One last item to consider. I am not ruling out a supercharger, next year, would that effect your decision?
I would probably look at Dart Pro 1 180cc heads as it stands, as a 350 MR with no big cam and no SC.
If I were to change cams, to LT4 hotcam or CC305, for example, I'd personally go with a 195cc Trickflow or Dart Pro 1 200cc. Those would not be restrictive, should I later go to 383+ with a new motor.
