WOW!
Old Sep 10, 2001 | 08:37 PM
KNCRSR5R's Avatar
KNCRSR5R
Default WOW!
HE HE HE........
I just did the TB bypass trick. WOW.....I cant beleive how COOL the TB is now! I used to burn my hand and now the whole TB and most of the Plenum is cool to the touch! I dont know exactly what this accounts for but it has to be something! Anybody know the facts on it??
HE HE...I still cant beleive it! :D :D :D
Oh yeah.....that frisbee on the water pump pully.......makes a better counter weight for our fork lift! :crazy: ITs gone!
Old Sep 10, 2001 | 09:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: WOW! (KNCRSR5R)
I've always believed that running 180-220 deg coolant through the TB has to put heat where don't want it, i.e. into the intake system.
My TB & plenum run cooler after I did the TB coolant bypass too.
Old Sep 10, 2001 | 09:36 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: WOW! (65Z01)
How is this bypass done?
Old Sep 10, 2001 | 11:52 PM
KYVette90's Avatar
KYVette90
Default Re: WOW! (vettes rule)
Drain your coolant. Remove the heater hose off of the passenger side of the throttle body. Then remove the u shaped hose that runs from the drivers side of the throttle body to just below on the intake. Insert a hose coupler into the end of the passenger side hose and clamp it and run about a foot of new heater hose from the other end of the coupler to the coolant fitting on the intake. Clamp it all down and your done. You can cap off the throttle body fittings if you want. :smash:
Old Sep 10, 2001 | 11:57 PM
TJR's Avatar
TJR
What I'd like to know is, what was its factory-intended purpose?
Old Sep 11, 2001 | 12:02 AM
Romeo Barrera's Avatar
Romeo Barrera
Default Re: WOW! (TJR)
To prevent icing of the throttle plates in colder climates, which you and I will never have to worry about :cheers:
Old Sep 11, 2001 | 12:16 AM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: WOW! (Romeo Barrera)
I did NOT drain my fluid. My car sat for about 1 1/2 hrs and then did it. I took the U shaped connection off the base of the TB. Then Took the passenger side off the TB. Then connected the two together using a smaller diameter pipe and original clamps. NO FLUID SPILLED AT ALL. I was surprised by this. no a drop...i thought maybe a little bit at least...but none! I need to go to the store and get some 3/8" caps for the TB to keep it clean...but thats it! 10min job for sure!
:cheers:
To WOW!
