There are 10 different fusible links that I'm looking at here. I'm trying to find out which one the fuel pimp is connected to because it didn't prime this morning before start up. Any idea which one it is? They all look very similar...
I gotta get this car running by the afternoon. Thanks.
Looks like it has an ORANGE wire coming out of it, at least thats what ALLDATA shows. All the others look like the output wires should be red. If its any help, it does look like the same fuse link powers the ECM, the MAF relay, the MAF burnoff relay and the oil sender switch. If any of those have power to their ORANGE wires the fuse link is good. there is also a fuel pump fuse in the fuse box. Did you check that?
Location wise it should be by the battery.
Always difficult to pinpoint, but that link also provides memory power to the ECM, Pin C16, and the MAF relays, along with Oil Pressure Switch and then the Fuel Pump Relay. Are they all dead? Anyway, find the connector off of the battery positive cable (which you can use to clear ECM memory) and follow it to that fusible link - I don't remember it being on the junction block.
Don't know if this will help, but it says: Fusible link H (distrubition box to relays which includes the Fuel Pump Relay). looks in the diag like it goes from the battery fusible link to H + E & D fusible links...
Is there power to the FP relay. If there is power at the relay then this is the place to start checking ot find the problem with the FP. Try switching one of the other relays in place ofthe FP relay to see if it works then. If so you need a new relay.
There was no voltage to the fuel pump. I checked the link. Infinity ohms. Thank God... and once again, thank you CF for aiding me with the immediate diagnosis!
Oops, the nut to the positive cable junction is now stripped. Where can I get a new one? The homies at Vatozone and Advanced Discount Auto Parts say, "We ain't got none!"
Isn't this a common American car part????????????????
Yes, it's a .5 orange fusible link. NAPPA sells them, their part number is 784691, BUT the one they sell is BLACK, I wrapped mine with red tape.
If you're getting an infinity reading on the fusible link..it's blown! The link can be attached to either the positive terminal or the power terminal behind the battery. The part number I posted has the connection for battery. But you can also buy a roll of 16 guage fusible link wire...if you go this route, use NO MORE than 9 inches of the fusible link wire...per Belden.
If your car cranks and starts it is not the link, because both the circuit to the fp relay and oil pressure switch run off the SAME fusible link.
BTW, I really suspect the wires GOING into the relay as be suspect for your problems and the cause of blowing the link...you should have seen mine..insulation shrunk back 1-2 inches, bare wires touching, and others have posted the same thing.
Thought I posted this before.
The problem, if there is one, is where the insulation of the wires shrinks back from the terminals in the plug. With the plug off of the relay, you can easily see if the typical insulation shrinkage problem exists. Since you ask, I'm betting it doesn't.
Does "Pfff..." mean that the insulation has pulled back from the crimped on terminals in the plug? A good, not so temporary fix, is to tape them up, well, so they can't make contact with one another. What about...?
Originally Posted by kopbet89c4
Its really funny that the wires look good going into the FP relay. How do I take apart the harness to find out if there is any bare wire exposed?
Just disconnect the FP relay from the firewall....don't just unplug the relay, IF memory serves me correct, once you pull the FP relay housing from the firewall...you should be able to see if any of the wire insulation has shrunk back exposing the bare wires. Someone else has posted about a MAF problem..and relays, look at his post..he too found what I've been talking about.
BTW, it's not wires going into the harness.....it's the wires going into the FP relay connection...that is where I believe you're gonna find your problem.
The post I referred to is by K87ZZ4
