Help! Sticking Throttle
Old Sep 3, 2006 | 05:12 PM
DaveN355's Avatar
DaveN355
Default Help! Sticking Throttle
I hope someone can point me in the right direction.
I was taking my 1994 6spd coupe (LT1) out to check to see if I got rid of some interior rattles I had worked on. Everything was running fine for several miles. I got on a stretch of road and decided to put the cruise on. The car held steady at 61mph at about 2000-2100 rpm.
When I went to stop, I pressed on the brake and noticed that the engine was still reving at 2000-2500 rpm. I shut off the cruise, no difference. I pressed in the clutch and stopped the car. After checking under the hood (the throttle cable was not broke and seemed to operate correctly). I restarted only to have it rev up to 2000-2500 rpm.
The entire trip home (~15 miles), the engine would only rev below 2000 rpm if I bogged it down. Clutch in, right back to 2000-2500 rpm.
At home, I checked the codes and only got the standard C12.
Any thoughts as to where to look first?
I did a search on similar problems. Given that it happed all of a sudden (was working fine earlier and the day before), I kind of doubt a vacuum leak (which was one suggestion). Also, it seemed to happen after I put the cruise on and at the approximate engine speed I was at when I set the cruise. Is there a way for the cruise to stick on or is this coincidental?
If it's not one thing, it's another.
Thanks in advance.
Dave
Old Sep 3, 2006 | 05:16 PM
Pete K's Avatar
Pete K
With the engine off, grab the throttle body linkage(where the cables attach) and wiggle. If they wiggle more than a little bit, you may have a worn out throttle shaft. This causes the butterflies to bind in the bore.
Old Sep 3, 2006 | 05:30 PM
RRT vette's Avatar
RRT vette
Good suggestion, also you may want to check to see if the TPS hasn't crapped out.
Old Sep 3, 2006 | 05:39 PM
kittmaster's Avatar
kittmaster
When mine stuck I used mobile 1 oil on the butterfly shaft and all surrounding rotational bearings. I relube it like every 3 years, but works every time as long as there is no slop in the mechanism
Old Sep 3, 2006 | 05:58 PM
rich653's Avatar
rich653
I always go back to when the problem started and it sounds like that was when you engaged the cruise, I think I would disconnect the cruise cable from t-body just to be sure nothings binding, it's easy and nothing to lose.
Old Sep 3, 2006 | 06:10 PM
DaveN355's Avatar
DaveN355
Thanks! I'll take a look at it tomorrow. I had wiggled the throttle cable and it wasn't what I'd call loose. I'll try to disconnect the cruise cable to see if that cure it.
Dave
Old Sep 3, 2006 | 07:56 PM
DaveN355's Avatar
DaveN355
I got it fixed! Rich653 was on the right track.
It turned out that when the cruise control was engaged, the ECU would slide down a little and not allow the cruise control servo to return to normal (and thus always had tension on the cruise throttle cable).
I recently did a brake job and had to move the ECU to get to the cap on the brake master cylinder. I must of not got it back in the right spot.
Thankfully it was simple fix. Thanks for everyone's help.
Dave
To Help! Sticking Throttle
