Started taking apart the upper end today,PITA everything is tight and I have big hands got it down to the intake 1 of the torx head bolts stripped I have the front off down to the timing cover took about 4hrs my tools are kinda scattered,looks like i'll spot weld a bolt on top of the intake bolt to get it out,The tpi intake is a major pita glad I'm dumping it,I'll get some pics when I'm further along
Its an 85 I'm running cast iron chevy bow tie phase 3 heads 184 cc runner with 64cc chambers stock flat top pistons, comp cam xfi flat tappet cam 520./515. 268./280. 1.6 rockers.You think I'll notice a difference over stock?
I think you need to use a 87 dist.with the external coil.This site is the best one I have found for that convertion.from parts list to step by step instructions with pictures.
big distrib fits ez with the machine work as done by the local shop...no need to chop vette wiring harness or use 'adapter' like the small distrib requires...small distrib is junk compared to the big one, probably why the vette never used it...mounting the external coil is a pita--btdt
Redrose,Im taking your advise and rotating stock fpr(F body rail), fab stock hold down bracket,spin fuel return line 180* same with the feed line so they can attach to the fuel lines at the passenger side front of motor,the big dizzy clears no problem
Update,taking my time as I'm working on the house at the same time,I have the new heads and cam installed,found out I need a damper or repair the one I have?Also sat intake on the heads all looks well,question, what is the flat sensor on top of an lt1 intake located behind the TB?I see some conversions with and with out it(plugged)?I hope to have it all together in a month,I will also need a chip,no need for pics till its done you all have seen a motor apart,take care
Also sat intake on the heads all looks well,question, what is the flat sensor on top of an lt1 intake located behind the TB?I see some conversions with and with out it(plugged)?:
WRONG WRONG
That sensor is the IAT or Intake Air Temperature sensor. It's used for Speed Density management. And only if the MAF fails on 94 and later engines. Limp home mode. So says the FSM.
[/WRONG]
[EDIT] That's the MAP sensor. {The IAT is in the air duct}
If you are doing any kind of SD engine management you'll need that sensor.
Question Can I run this combo without a chip tune for the first 1/2 hr?,reason is if the intake for some reason won't seal up,I will be switching to a **** and would not need a chip,that would be last resort.But I would like to run it first before doing the chip,what do you guys think?I'm getting close,If I did it again I would buy something bolt on or have all the intake work done.Anyone have luck bending the fuel lines on the lt1 rail??
mine and several others here run great on the stock chip....mine data logs just a tiny bit rich when the battery is disconnected and the ecm has to relearn.
you can bend the fuel line with one of these, harbor fright sells it for $7
