lt-1 intake w/ L98 dist prob
Old Sep 4, 2006 | 02:04 PM
redrose's Avatar
redrose
Default lt-1 intake w/ L98 dist prob
some time back, a problem surfaced with lt-1 intakes converted to use the L98 distributor (these are fairly common locally on sbc-1's in cars and even more in 4x4's that use a transplant lt-1 engine assy from a caprice to get great power, with a ''big'' HEI to avoid opti and ecm pains )...the distr hold-down bolts were ''stripping out'', possibly due to over-tightening to stop the distrib from ''walking'' and retarding timing or possibly due to insufficient metal thickness of the lt-1 manifold in the area where the new distrib hole is made, leading to flex in that area.
the cure, devised by my local machine shop, is a ''wedge plate'' that reinforces the manifold, sets the distrib at correct height and 5* mount angle, and provides three distrib mount holes at the height for proper clamping action...using 2 dist clamps is recommended. ''A'' is the oem hold-down location, and directly opposite is a new hold-down point; the dark bolt head is the third point...''B'' is the plate mount screws that thread into the manifold...''C'' is a plate mount screw that threads into the manifold and has a nut/washer underneath
if there is interest, a few of these plates MAY be available, with dimensions for plate location on the lt1 manifold (the machine shop levels this area on a milling machine prior to plate installation but careful hand file work would do)
Old Sep 4, 2006 | 02:12 PM
Pete K's Avatar
Pete K
If available, and the cost is fair, I would be interested.
Old Sep 4, 2006 | 02:29 PM
87 rag's Avatar
87 rag
I would be interested. Actually I am interested.
Old Sep 6, 2006 | 07:14 PM
canon1414's Avatar
canon1414
I could be interested too
Old Sep 7, 2006 | 10:21 AM
redrose's Avatar
redrose
finally got a price !!!.. see the f/s section
Old Sep 7, 2006 | 02:41 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nice to see someone stepping up to the plate on this one.
Here's the link for you
http://forums.corvetteforum.com/show....php?t=1492915
To lt-1 intake w/ L98 dist prob
