Is this normal??
Old Sep 4, 2006 | 08:35 PM
photoguy's Avatar
photoguy
Default Is this normal??
I have a 91 L98 with no mods. In the morning when I start up it runs rough and sputters until the engine is warm then it runs normal.
It only does this after sitting overnight. I just changed the plugs and air filter.
Any suggestions on what to look for next or is this just normal. I have 49,000 miles on it.
Thanks.
Old Sep 4, 2006 | 09:14 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
It sounds like it is running rough when in open loop, and then adjusting once in closed loop. Are you getting a SES light? Did you pull for codes? Do you have (access to) a scanner? I'm not as familiar with the speed density systems, but a scan during operation would probably point you / us in the right direction.
Old Sep 4, 2006 | 09:15 PM
photoguy's Avatar
photoguy
No SES light!
To Is this normal??
