cam?
Old Sep 4, 2006 | 10:48 PM
Mallett Z's Avatar
Mallett Z
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
Default cam?
Hello,
im looking to get some insight on what cams are available and which cam would fit my goals. I'm pretty much an idiot when it comes to this as i am somewhat new to the moding scene. my goals are to have a quick street car. i dont get to the srtip often so i really dont have a 1/4mile time goal. I want it to be reliable in both city and highway if i decide i want to take a road trip(gas mileage not an issue, i didn't buy a vette to be concerned about mileage!) My next question is if i get a cam what needs to be done to the heads? i am starting research now so i can be well educated when i go through with this possibly next year. any help tips and ideas are much appreciated!
TIA!
*car is a 96 LT4*
Old Sep 4, 2006 | 11:42 PM
SHINOBI-X's Avatar
SHINOBI-X
Your heads flow a decent amount better than LT1's and most use the GM hotcam with excellent results. Most opt for the Compcams CC305 or GM Hotcam because the LT4 heads already flow really good. Heads can be improved but just a cam and a custom tune will be good.
Old Sep 4, 2006 | 11:54 PM
Mallett Z's Avatar
Mallett Z
correct me if im wrong the cc305 is slightly bigger than the hot cam correct?
Old Sep 5, 2006 | 12:49 AM
SHINOBI-X's Avatar
SHINOBI-X
yes sir it is. I'd buy a CC304 for a stock LT1 motor with unported heads and a CC305 for a stock LT4 with unported heads. An over cammed motor kills street manners and low-end torque. I know you want those street manners so I'd say stick with the HOTCAM or CC305. The CC306 is huge for a street car or say daily driver.
Old Sep 5, 2006 | 12:56 PM
clf93lt1's Avatar
clf93lt1
http://www.wku.edu/~nathan.plemons/h...rformance.html
Old Sep 5, 2006 | 01:00 PM
SHINOBI-X's Avatar
SHINOBI-X
Those 1.7 rockers have always caught my eye....they proved to work well with that cam
Old Sep 5, 2006 | 04:02 PM
Mallett Z's Avatar
Mallett Z
nice page Thanks!
Old Sep 5, 2006 | 05:11 PM
clf93lt1's Avatar
clf93lt1
Thank nathan he did a lot of work, and put it out there for everybody,
Old Sep 5, 2006 | 08:13 PM
Mallett Z's Avatar
Mallett Z
well im thinking im going to go with the cc305, am i safe with stock springs or would it be better to get something diffrent, what ratings should i look at if its best to change? thanks for all the help so far.
Old Sep 5, 2006 | 08:27 PM
STL94LT1's Avatar
STL94LT1
The stock springs are just barely good to .525 lift. Personally, I would upgrade the springs with any cam change.
Old Sep 5, 2006 | 09:32 PM
Mallett Z's Avatar
Mallett Z
i guess they arent that much more expensive and the extra piece of mind would be worth it. better not be a cheapscate, that way i'll only have to do it once.
Old Sep 6, 2006 | 09:51 AM
tequilaboy's Avatar
tequilaboy
You may also want to consider the Comp 503, or something from the XFI line, like the 466 or 467. Spend some time with the Comp Cams Catalog.
I would think you'd want something a little bigger and more modern than the Comp 305 for an LT4, considering the rev-capability of the LT4.
You'll be needing new valve springs for anything bigger than the hotcam, anyway, so why not make the most of it and exploit the lift.
Have you thought about gears yet?
Old Sep 6, 2006 | 10:41 AM
STL94LT1's Avatar
STL94LT1
For a near stock engine I like the 466 camshaft, and I would do 4.10 as my first serious mod.
Old Sep 6, 2006 | 11:16 AM
LT4BUD's Avatar
LT4BUD
I did compcams 503........
Today I would do CompCams 467 or 468....
LT4 hot cam is still a good choice, but I think a cam from the new XFI line would be todays best choice....
I opted for all new valve train due to higher lift..
Remember a cam is only one part of an overall performance package...
Old Sep 6, 2006 | 07:28 PM
Mallett Z's Avatar
Mallett Z
what kind of RPM's would i be running on the freeway if i were to get 4.10's? not too familiar on gears either
Old Sep 6, 2006 | 07:30 PM
STL94LT1's Avatar
STL94LT1
Around 1800 rpms @ 70 mph in 6th gear.
Old Sep 6, 2006 | 10:06 PM
Mallett Z's Avatar
Mallett Z
how much would it go up at 80? that is usually my freeway cruising speed
To cam?
Old Sep 6, 2006 | 10:14 PM
hippy's Avatar
hippy
Hotcam, 219 or whatever has under 220-225 intake duration to make a nice streetable cam.
I have a 219 with 1.6 in mine and it has damn nice power and still will get around 23ish mpg on the highway.
Old Sep 6, 2006 | 10:27 PM
tequilaboy's Avatar
tequilaboy
a nice gear calculator
http://www.f-body.org/gears/
Old Sep 6, 2006 | 10:50 PM
ALLT4's Avatar
ALLT4
blackLT496, you might want to check out this thread if you didn't catch it.
