Front end rattle
Old Sep 5, 2006 | 11:41 AM
freakinwalt's Avatar
freakinwalt
Default Front end rattle
I have a good rattle in the front end that rattles even on rough roads. It seems to be coming from the left front wheel assembly. I have replaced Balljoints and shocks, checked and tightened fender bolts and body parts. I think it is coming from the cross leaf spring in the front, and the jounce bushing is worn. Has anyone else dealt with this?
Thanks for any replies
Old Sep 5, 2006 | 02:14 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Check the "Anti-Rattle Clip" that is supposed to be atttached to the brake pads. It is a little curly-Q shaped metal piece that slips onto the pad. They sometimes give up and either break off from metal fatigue or even fall off.
The disk brakes are a free floating design and without the clips to provide tension will make a hell of a noise.
Old Sep 5, 2006 | 02:51 PM
SK.LT1's Avatar
SK.LT1
You may also want to check your sway bar end links.
To Front end rattle
