Gaseous intercooling
Old Sep 5, 2006 | 04:10 PM
93 ragtop's Avatar
93 ragtop
Default Gaseous intercooling
I am looking at the super standard kit from blowerworks. The kit does not come with the water tank. My question is, what are using for a water tank? I was considering using the windshield tank as this is not a daily drive for me and I could just disconnect the windshield washer line from the tank. Any opinions are appreciated.
Old Sep 5, 2006 | 07:23 PM
lcvette's Avatar
lcvette
sure.. just run a windshield washer fluid that is utilizes Methanol as its antifreeze component and you can multitask it and you have a fluid level low reminder gauge.. or do we have those on vettes? never checked on it.
CHris
Old Sep 5, 2006 | 08:47 PM
Mo_Bandy's Avatar
Mo_Bandy
i used mine as well i just recently went to the bladder system...
If you use the windshield washer make sure you put the pump as close to the water bottle as possible, there is room near the bottle
That by the way is the same system as i am using...
MO
To Gaseous intercooling
