Turn off Change Oil Light
Old Sep 11, 2001 | 08:06 PM
Vvcdde's Avatar
Vvcdde
Default Turn off Change Oil Light
Gotta 96 Corvette (no service manual) and the change oil light came on today and I need to know how to turn it off.
Anyone?
Old Sep 11, 2001 | 08:18 PM
Admiral Fairway's Avatar
Admiral Fairway
Default Re: Turn off Change Oil Light (Vvcdde)
Here's how it is done on a '94;
Turning off the change oil light
1) Turn the ignition "ON", but do start the engine.
2) Press the "ENG/MET"button and release, then, within 5 seconds, press it again.
3) Within 5 seconds of step 2, press and hold the "GAUGES" button. While the button is held, the "change oil" indicator will flash.
4) Continue holding the "GAUGES" button until the "change oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds. If it does not successfully reset, turn the ignition "OFF" and repeat the procedure from step 1.
Hope this helps.
Old Sep 11, 2001 | 08:22 PM
OcalaGuy's Avatar
OcalaGuy
Here Ya go, I hope this works.
The "Change Oil" indicator is reset by using a sequence of Driver Information Center (DIC) key presses as follows:
1. Turn ignition "ON", but do not start engine. (ALDL pin "G" should NOT be grounded.)
2. Press the "ENG/MET" button and release, then, within 5 seconds, press it again.
3. Within 5 seconds of Step 2, press and hold the "GAUGES" button. While the button is held, the "Change Oil" indicator will flash.
4. Continue holding the "GAUGES" button until the "Change Oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds.
If it does not successfully reset, turn ignition "OFF" and repeat the procedure from Step 1.
Here's a site with more information http://www.idavette.net/techno.htm
Old Sep 11, 2001 | 10:33 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: Turn off Change Oil Light (OcalaGuy)
ITS IN YOUR MANUAL!!!!! :cheers:
Old Sep 11, 2001 | 10:34 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: Turn off Change Oil Light (KNCRSR5R)
NEVERMIND. My bad. must have been :sleep: .
Old Sep 11, 2001 | 10:36 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
Read his post :mad . He stated he didn't have the manual! :smash: :smash:
Old Sep 12, 2001 | 06:08 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: Turn off Change Oil Light (96GrandSport)
READ MY POST........I STATED I WAS SLEEPING AT THE TIME! I said sorry. Man. :crazy:
Old Sep 12, 2001 | 09:00 PM
Fang S-289's Avatar
Fang S-289
ZZZZzzzzzzzzz LOL
To Turn off Change Oil Light
