need advice on my six speed please
Old Sep 8, 2006 | 02:54 PM
85autoxr's Avatar
85autoxr
Default need advice on my six speed please
i just took car for a small ride when i noticed my shifter was getting harder to put in gear.when clutch was engaging it did not seem to slip at all, is this probably just!! my throw out bearing? or should i order clutch kit and have it all done? erik.. p.s. i only put 550 miles on it when i bought it. i dont know when previous owner had it replaced if ever..94699 miles.......... thanks for any/all input. sorry im a moron left out car wont go in gear now, only way is to shut car off then restart..
Old Sep 8, 2006 | 03:48 PM
ultraviolet70's Avatar
ultraviolet70
Sounds more like a hydraulic problem, i.e. master cly or slave cyl. Both common issues with 6spd C4s. Do a search on the slave and/or master cylinder, you'll get more info than you want.
Old Sep 8, 2006 | 03:51 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Check the level of your hydraulic clutch master cylinder reservoir.
If it is low, top it off and see how it works.
If no improvement, try bleeding the system.
Go here: http://zfdoc.com for instructions.
Good luck!
Old Sep 8, 2006 | 04:01 PM
ultraviolet70
Well if the system is low I'd say top it off and test it but I doubt that will fix it because surely it will need bled. So if it is low something is leaking and would need replaced/repaired, and being the difficulty involved in properly bleeding these systems I wouldn't just want to bleed it for the hell of it and then say oh it needs a slave cyl let's put that on and bleed it again.
Find whats bad, replace it, than worry about bleeding it.
Old Sep 8, 2006 | 04:03 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
with previous posts - definitely sounds like a hydraulic fluid problem. It sounds like the fluid got pretty low; if the clutch master cylinder is empty, then there will definitely be air in the system. You will need to bleed it after you top it off. Check for leaks as well.
Old Sep 9, 2006 | 10:56 AM
85autoxr's Avatar
85autoxr
Default master culinder
i found clutch master almost empty. why?any ideas? erik...and thank you gentelmen
Old Sep 9, 2006 | 02:23 PM
ultraviolet70
Again check your slave and MC. Do so by removing drivers side hush panel and look under dash up where MC push rod comes through firewall, see if it's wet. Check slave cyl by raising car and removing two nuts which hold slave to bellhousing, slide slave out and inspect for moisture at boot.
Replace leaking component and bleed system.
Old Sep 9, 2006 | 11:35 PM
Dads90's Avatar
Dads90
Default Slave cylinder
There have been reports of people putting 2 or 3 cylinders in their C4. The GM brand had reports of the assembly being defective and takes reassembly to correct the problem. The Wagner brand I got from Rock Auto.com hasn't leaked yet. Note: Dont tear up the hydraulic hose(between the slave and master) its almost irreplaceable. Its tight quarters underneath so put it on a rack or jack stands. Good Luck
Old Sep 12, 2006 | 04:34 PM
85autoxr's Avatar
85autoxr
Default yup
it was slave cylinder leaking. all better now, thanks guys
To need advice on my six speed please
