Nitrogen filled tires?
Old Sep 9, 2006 | 02:14 AM
raisinbran's Avatar
raisinbran
Default Nitrogen filled tires?
I just learned that some tire shops offer this option. I know air is already 78% nitrogen, but apparently things like water vapor is also eliminated when filled with pure nitrogen. Anyone had any experience with this? Is it worth it?
Old Sep 9, 2006 | 07:49 AM
cshuman's Avatar
cshuman
I've got it in mine and it did improve the ride. Go by one of the tire places that install it and get a handout. It will explain all the advantages.
Old Sep 9, 2006 | 08:56 AM
redrose's Avatar
redrose
we are about 400 ft above sea level here--that means that the ''boiling point'' of water is 210* F....we race supermods on an asphalt surface and our tire temps get over 210* on warm evenings...when the ''water'' inside the tire changes state and becomes ''steam'' it expands to 1600 times its ''water'' state and altho its a small amount of water, that volume change has an undesireable effect on the handling of the car as it kicks up the tire pressure....while we have a smart bunch of turnips in our crew and could work around this , it is easier to simply use a ''dry'' gas--compressed ''nit'' is a cheap commodity and is easier to carry than an air compressor as a side benefit.
for street use?--just a gimmick.
Old Sep 9, 2006 | 09:39 AM
vader86's Avatar
vader86
Pointless for street use.
Old Sep 9, 2006 | 09:44 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Well, raisinbrain, if you can get it for free, why not?? I wouldn't go out of my way just to have nitrogen in my street tires...
One thing you've overlooked here; inside the tire, it is at 30psi gage, or about 10,000ft BELOW sea level, which means the water cannot turn to vapor (boil) until it hits about 600 degrees F. (all these numbers are literary license, and not really accurate, but you get my point....)
Ya' havta' consider everything.....
Larry
code5coupe
Old Sep 9, 2006 | 12:31 PM
GKK's Avatar
GKK
The Nitrogen molecules are larger and more dense than air molecules and will not leak from the tire.
If you fill your tires with Nitrogen to say 35 psi, and check the tire pressure in a month, the tire pressure will still be 35 psi. That's the advantage for passenger cars.
Old Sep 9, 2006 | 01:16 PM
runner140*'s Avatar
runner140*
Its pure marketing, my .02 .
Old Sep 9, 2006 | 01:28 PM
93 ragtop's Avatar
93 ragtop
That is what I have been told as well. I know costco is offering it and there is no charge for it.
I would like to add, in AC work we use it for leak testing. It is dry, so there is no acid problems with using it and it is very stable. Tempatures do not cause it to change pressures.
Old Sep 9, 2006 | 02:20 PM
rocco16's Avatar
rocco16
"Tempatures" will, indeed, cause it to expand and contract...just not quite as much as air will.
Racers can use this characteristic, street drivers won't.
The ONLY benefit from filling your tires with nitrogen is more stable pressures..slightly. Frankly, how many of us can tell the difference between 34 and 36 psi in our tires, anyway?
Larry
code5coupe
Old Sep 9, 2006 | 02:21 PM
CFI-EFI's Avatar
CFI-EFI
I'd LOVE to hear the argument for THAT.
RACE ON!!!
Old Sep 9, 2006 | 02:26 PM
jfb's Avatar
jfb
Unless you evacuate all the atmospheric air from your tire before you inflate it with nitrogen, your tire will still have water vapor in it and the benefits from nitrogen will not be there. Compressors that use an intercooler will have water free compressed air and at a cost much much lower than dry nitrogen.
Old Sep 9, 2006 | 02:27 PM
jfb's Avatar
jfb
RACE ON!!!
Its psychological, heck, even sugar pills are 25% effective in double blind drug tests.
Old Sep 9, 2006 | 03:11 PM
merlot566jka's Avatar
merlot566jka
i have a second job at costco tire center....i put it in my car...didnt notice a damn difference. supposedly leaks slower...totaled my vette 3 days later...maybe it was the nitrogen...? lol, it wasnt, but yea the stuff is just a marketing tool!
Old Sep 9, 2006 | 03:20 PM
Richard G's Avatar
Richard G
Nitrogen is an oxygen scavenger, it would let your tires last longer on the inside, less oxidation. I will go with air on my compressor.
Old Sep 9, 2006 | 04:10 PM
jfb's Avatar
jfb
I have been driving for 43 years, driven in excess of 1/2 million miles, wore out and replaced many sets of tires, owned one at a time, 4 vettes, not one tire of mine nor have I ever heard of anyones tires oxidizing on the inside and causing a problem. Also, nitrogen is chemically inert at normal atmospheric temperatures and it does not scavange anything except money out of your wallet when you buy into the ,"benefits", of it inflating your tires.
Old Sep 9, 2006 | 04:29 PM
93 ragtop's Avatar
93 ragtop
Larry
code5coupe
to a degree. (no pun intended ) I would like to see someone take the time to fill 2 tires with nitrogen and 2 with air. Check pressures cold and hot and see how much difference it makes. I believe it would be less with nitrogen but who knows. Again, I have it in my truck due to the fact when costco put the tires on that is what they use. By the way, they put these green valve stem covers on when they change the tires.
Old Sep 9, 2006 | 05:14 PM
toptechx6's Avatar
toptechx6
Nitrogen? Hell, that's old technology, I use helium in mine, reduces unsprung weight and cut 2 tenths off my ET and if you think they ride good filled with nitrogen, wait till you try helium!
To Nitrogen filled tires?
Old Sep 9, 2006 | 05:17 PM
kpforce1's Avatar
kpforce1
Don't NASCAR and indy car teams use nitrogen filled tires?
Old Sep 9, 2006 | 06:37 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Larry
code5coupe
I'm with Larry on this. All gasses expand or rise in pressure when heated (PV=nRT). IIRC, nitrogen has a slightly higher specific heat than oxygen (the other major component of air), so pure nitrogen should show a slightly smaller pressure rise than an air filled tire, but I'm guessing most of us racer wannabees wouldn't notice the difference.
Additionally, JFB has a good point about it all being pointless if the tire isn't first purged of air and moisture.
Old Sep 9, 2006 | 08:17 PM
CFI-EFI's Avatar
CFI-EFI
Shhh! I've been trying to keep a lid on that info, so I can maintain an edge over the competition. BTW, hydrogen is even lighter still. Remember the Hindenburg? Shhh!
RACE ON!!!
