Compressing Rear Calipers
Old Sep 10, 2006 | 12:02 AM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
Default Compressing Rear Calipers
What is the "Easiest" way to do this?
Old Sep 10, 2006 | 12:55 AM
jfb's Avatar
jfb
Loosen brake bleed screw, push on caliper piston, tighten bleed screw.
Old Sep 10, 2006 | 08:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I remove the cap from the master cylinder and squeeze with my fingers(I insert an old pad backwards first so I have something to press on).
Old Sep 10, 2006 | 08:32 PM
Da Mail Man's Avatar
Da Mail Man
i had heard that if you depress the caliper having abs brakes, there exists the possiblilty of blowing the abs pump. regardless if this is true or not, i have had a few shops tell me this. better safe then sorry!
Old Sep 11, 2006 | 08:22 AM
Steel Blue 91's Avatar
Steel Blue 91
Frank seems to be spending more time at the gym than me 'cause I just use a large C clamp. Just make sure you suck some of the fluid out of the master first.
Old Sep 11, 2006 | 08:26 AM
midlifecrisis91
Thanks for the tips guys.
To Compressing Rear Calipers
