Oversized Plenum gaskets
Old Sep 12, 2001 | 12:44 PM
KYVette90's Avatar
KYVette90
Default Oversized Plenum gaskets
I've just ported my plenum and I need some new gaskets. They have to be bigger than stock. I know you can get stock ones and cut them open bigger, but I was wondering if anyone knows where I can buy some oversized ones, maybe for the siamesed runners? Anybody know? :confused:
Old Sep 12, 2001 | 01:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Oversized Plenum gaskets (KYVette90)
I believe TPIS has larger gaskets since they sell the LT runners. Try SLP for siamesed ones.
Old Sep 12, 2001 | 02:39 PM
Dave's_88's Avatar
Dave's_88
Yup, TPiS part #100-011, Tuned Port Gasket Set, Large Tube, $18.00
-Dave
Old Sep 12, 2001 | 08:51 PM
KYVette90's Avatar
KYVette90
Default Re: Oversized Plenum gaskets (Dave's_88)
Thanks for the part number. :cheers:
Old Sep 12, 2001 | 10:20 PM
JAKE's Avatar
JAKE
I used the stock size ones after I REALLY opened the runners, plenum and manifold.
I placed the gaskets on the runners, used bolts, washers and nuts to hold them in place. I then used my high speed Makita grinder with a very fine tooth carbide bit to remove as much gasket material as needed.
I periodically placed the gaskets on the plenum and manifold to make sure the gasket mods were matching.
Pretty simple and worked great.
Jake
To Oversized Plenum gaskets
