1991 Hesitation
Old Sep 12, 2006 | 06:54 PM
hgoodwiniii's Avatar
hgoodwiniii
Default 1991 Hesitation
Hi everyone. I am having trouble with my 1991 coupe. When I take off from a stop such as a red light or stop sign, the car hesitates and actually sounds like it flutters. The car actually acts like it it wants to shut off but usually does not (it may have actually shut off twice with this problem). The car does this unexpectially, it does not do it all the time and it happens very quickly then it does it. Other than that, it runs very well. The last suggestions I received about this suggested I change the fuel filter which I have done. That has not helped the problem. Does anyone have any idea what could be causing this hesitation/fluttering? Thanks.
Old Sep 12, 2006 | 08:44 PM
RRT vette's Avatar
RRT vette
First thing I think of is inadaquate air flow at the time needed or possible EGR inop. Has the SES light come on? If you haven't cleaned the TB and IAC it would be good to try it.
Old Sep 12, 2006 | 08:45 PM
polo91cnvt's Avatar
polo91cnvt
Had a simalar problem on my 91/L98. Driving down the road and it would appear to shut off and restart within a second, may less.
I believe I solved it by removing the EMC connections and reattaching them, but also around the same time I my TPS went bad and I replaced that and retuned the idle. It has run great since.
I would check your TPS voltage to make sure it is correct, and replace if it is not, as well as reatach the EMC connections.
Good Luck Polo
Old Sep 12, 2006 | 09:34 PM
hgoodwiniii
Default 1991 hesitation
Thanks for the suggestions. I'll try them all. I'm thinking the EGR. The SES light is not on. It did come on a few months ago and I scanned the engine @ that time. The code was "EGR not operating" but when I scan now, I do not get any trouble codes. I'll try it again. I've changed the TPS earlier this year. What do I clean the Idle Air Control with?
Old Sep 12, 2006 | 09:42 PM
RRT vette's Avatar
RRT vette
You will need to remove the throttle body and then remove the IAC from the bottom. Clean the inside of the TB with throttle body cleaner and old toothbrush. While the IAC is out clean it and the IAC air passage inside the TB where the IAC motor pintle lets more or less air in. Clean it the same as the TB. The IAC gaskets are not sold and you will either need a sheet of gasket paper to make one or buy a new IAC ($30) to get the gasket. Also install a new TB gasket as well. Put it back together and check the TPS voltage (.54v) with a VOM if you have it or just be careful not to bump it.
The EGR is not active at idle or WOT and only while accelerating or cruising. The EGR solenoid is the usual suspect. The ECM controls the opening and closing of the solenoid according to throttle postion. Also check the vacuum lines to the EGR and TB.
Old Sep 13, 2006 | 02:30 PM
hgoodwiniii
The EGR solenoid has been dicontinued according to my GM dealer contact, O'riley autoparts and Eckler's. Any idea where I can find one if needed?
Old Sep 13, 2006 | 02:45 PM
RRT vette's Avatar
RRT vette
I just searched all over the web at places I would think carry the 86-91 EGR solenoid. I found none. All said they were discontinued or not available. I'm interested also for future repairs although my EGR is blocked off and disabled.
Old Sep 13, 2006 | 11:33 PM
hgoodwiniii
You can find a EGR solenoid @ Dino's Corvette Salvage. The number is 1-888-467-8388. Here's the link. http://corvettesalvage.com. Also, my SES light finally started reacting to the problem. I scanned the car and I am getting a code of 43. Knock Sensor. I went to the GM service manual and it recommends several test. I'll try them tomorrow. For future reference, if the EGR is bypassed, does that cause the SES light to remain on?
Old Sep 14, 2006 | 09:33 AM
LS6 Motor's Avatar
LS6 Motor
You can get a new solenoid from Advanced Auto Parts, or if you don't have a store near you, order it on line @ advanceautoparts.com. They are a GP Sorensen piece, and they are $53.00 each. I replaced the unit on my 1991 when I did the EGR valve.
Old Sep 14, 2006 | 10:20 AM
mseven's Avatar
mseven
Most 90-91's don't have an adjustable TPS (even though the fsm states to adjust yours, a non-adjustable will probably read .6 or so, it won't matter TP angle will still be 0%) MAP cars do not depend on TPS in the same way a MAF car does for calculations. However, put the vohm on it and gradually turn the throttle looking for a gradual increase in voltage and no dead spots.
Old Sep 14, 2006 | 02:06 PM
kopbet89c4's Avatar
kopbet89c4
I had a problem like this once. After almost 5 months with this intermittent idiot problem, it was a faulty oil pressure switch and the FP relay. A combined $30 worth of ****ty parts causing this aggravating and potentially dangerous problem, e.g. left hand turns on intersections. Haven't stalled yet ever since both were replaced.
Each time my car acts up, I think... air, fuel, or spark. What's missing?
To 1991 Hesitation
